Check Engine Light
Old Sep 27, 2006 | 02:56 PM
rx8beachgirl's Avatar
Check Engine Light
My check engine/service engine light just came on. I have about 21,000 miles on my 2005 RX8 and was wondering if anyone else had this happen? Hopefully it's just an oxygen sensor or something simple. Thanks for the feedback!
Old Sep 27, 2006 | 03:24 PM
no dice's Avatar
I bomb atomically
..its impossible for any of us to know what your check engline light meant. do us all a favor and head over to your dealer and have them pull the code. Its most likely a loose gas cap..
Old Sep 27, 2006 | 03:29 PM
loose gas cap is very often the culprit. Don't bother trying to use a OBDII scanner to pull the code as it will unfortunately not work.
Let us know...
Old Sep 27, 2006 | 03:35 PM
Subdivisions's Avatar
Check your fuel cap.
If you don't tighten the cap enough/correctly the CEL will come on.
Tighten the cap and the light "may" reset.
It takes a few days though (maybe 8-10, depending on how much you drive)
Old Sep 27, 2006 | 03:42 PM
no dice's Avatar
I bomb atomically
it takes about 3 start up shut down cycles..
Old Sep 27, 2006 | 04:48 PM
NoTears316's Avatar
Shock and Awe
Werd, check gas cap.
Old Sep 27, 2006 | 10:48 PM
Urchin's Avatar
Also check the following thread https://www.rx8club.com/series-i-trouble-shooting-95/continuing-engine-light-problems-anyone-98521/
Zoom44 says if the light comes on while driving, not likely the gas cap. For me it was (hopefully) a purge valve and a loose hose to the purge valve. Hopefully that has fixed it.
Old Sep 27, 2006 | 11:20 PM
Easy_E1's Avatar
Visit the Dealer. That's why we have warranty.
(Most of us)
Old Sep 27, 2006 | 11:34 PM
sunilseru's Avatar
My car's CEL came on while I was driving. Definitely did not go away after 3 start/stop cycles. Turned out to be the loose gas cap. Nothing serious...
Old Sep 28, 2006 | 11:14 AM
no dice's Avatar
I bomb atomically
I didnt clarify, it will take 3 start stop cycles to auto reset the CEL if the actual cause is no longer present..
Old Sep 28, 2006 | 11:27 AM
DARKMAZ8's Avatar
"Call me Darkman"
Open up the hood and check
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
