Passenger air bag on/off?
Old Sep 26, 2006 | 02:55 PM
roland_beech's Avatar
So in some threads people say the 2006 Rx-8's have a passenger side sensor for the airbag.
Could someone elaborate on this and how it works? It doesn't seem like a simple on/off switch you control, but it adjusts based on weight?
Old Sep 26, 2006 | 02:57 PM
Aseras's Avatar
yeah weight sensitive, overseas models have a on off switch, it's what the hole beside the glovebox is for.
Old Sep 26, 2006 | 02:59 PM
BunnyGirl's Avatar
The seat senses if there is weight on it and if it is less than 69 pounds it deactivates the airbag. Otherwise, you can't just turn it off.
Old Sep 26, 2006 | 03:00 PM
Thanks BunnyGirl and Aseras!
Old Sep 26, 2006 | 03:01 PM
BunnyGirl's Avatar
The "hole" beside the glovebox in mine (an 06) is a light that says "passenger airbag off" when you turn the car on or if after the car is on you put something on it that weighs less than the above mentioned weight. It stays lit for several seconds.
Old Sep 26, 2006 | 03:03 PM
BunnyGirl's Avatar
It deactivates under 69 pounds. So 70 pounds and up you're covered although it recommends not sitting there if you are somewhere around 100 pounds or less, I beleive. It was high 90s or something.
Old Sep 26, 2006 | 03:15 PM
Fuel4theFury's Avatar
Rotary Magic
Haha you said 69 But yeah, why would you wanna turn it off? You wanna kill your passenger dont you
Old Sep 26, 2006 | 04:35 PM
Phantom 4 Door's Avatar
Think outside of the BOX!
switch always gets me when I throw my bookbag in the passenger seat...
"WTF IS TH--...ohh, my bag"
Old Sep 26, 2006 | 04:49 PM
otherside's Avatar
I dont care...
Accually, its 66 lbs...But thats not as fun as 69
Old Sep 26, 2006 | 04:51 PM
moRotorMotor's Avatar
Rotary eXperimental-8
So this only applies to '06?
Old Sep 26, 2006 | 04:53 PM
otherside's Avatar
I dont care...
^^ Yes
Old Apr 29, 2023 | 10:36 PM
tet024's Avatar
Hi,
Yesterday I got my first RX-8 but it has a small fault. My passenger airbag is remaining off even when I a passenger sits down on it. Also I noticed that when a the car is moving and the Passenger seat belt is removed there is no warning that the seat belt is removed. Can someone kindly help me on how to trouble shoot the issue. I took a look under the seat and the connections all seem tightly fitted.
Et
vapor2
May 4, 2020 03:53 AM
SimonT182
Oct 2, 2015 10:33 AM
Danield97
Sep 30, 2015 05:59 PM
tommy26Germany
Sep 29, 2015 10:33 AM
drlubell
Sep 26, 2015 11:58 PM
