LC-1... three grounds... where?
Old Sep 25, 2006 | 08:33 PM
kenkamm's Avatar
Got the LC-1 from Innovate. I did read the instructions and I did do a search here, but I'm still not absolutely sure where the best place to place the three grounds are. The instructions seem to contradict themselves.
"The BLUE, WHITE, and GREEN wires should all be grounded to the same ground source and although these grounds are of the same source, the BLUE wire should be wired separate from the WHITE and GREEN wires to avoid analog ground noise."
Then in the very next paragraph it says:
"Note: The LC-1’s heater ground (BLUE), system ground (WHITE), and analog ground (GREEN) wires should be grounded at the analog input’s ground."
In my case, the analog input's ground is the eManage Ultimate, which doesn't have a local ground, but rather is connected only to the ECU harness.
I read on Innovate's forums that the three grounds should be connected to the same area, but not the same exact spot or grounding lug.
Anyone have any experience or advice for this? I doubt I'm going to find a perfect ground in the ECU box that has two points I can connect to that are the same ground but not the same point, etc... UGH
Old Sep 26, 2006 | 08:56 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
Great question and at the perfect time! I am getting ready to install my LC-1 and I don't exactly know how I should wire it either? I plan on using it with the emanage ultimate.
I know that the LC-1 power can be wired to the cigarette lighter but I was wondering if it would be alright to wire it to PCM Pin 4Q? In the EMU turbo upgrade kit harness, this is where the EMU power wire is connected. This would allow both the EMU power and LC-1 power to be wired to the same place.
Also, it looks like there are 2 grounds in the ECU. One is PCM Pin 4J. In the upgrade kit harness, this is where the EMU main ground wire is connected. The other is PCM Pin 4A. In the upgrade kit harness, this is where the EMU Injector ground wire is connected.
I was thinking about wiring the LC-1 system ground (WHITE) and analog ground (GREEN) wires to PCM Pin 4J (with the EMU main ground). Also, I was thinking about wiring the LC-1 heater ground (BLUE) to PCM Pin 4A (with the EMU Injector ground wire). This would allow the BLUE wire to be separate from the WHITE and GREEN wires to avoid analog ground noise while still keeping all three grounds connected to the same area. Anyone else have any thoughts???
Old Sep 26, 2006 | 10:21 AM
kenkamm's Avatar
GTAW, thanks for your help. Just to be sure I understand you correctly, in part of your explanation you are saying to make a pigtail that will connect the existing PCM ground to a chassis location ground? In doing this, aren't you creating another ground path for the PCM? That's not a problem?
tdiddy, if your scheme worked, it would be easy to implement.
Old Sep 26, 2006 | 09:17 PM
kenkamm's Avatar
Well I got the LC-1 installed and for the life of me can't figure out how to get the EMU to read the AFRs properly. I am pulling my hair out here and searching isn't helping me, and reading the EMU manual and LC-1 manual doesn't help either. I've played around with the settings and can't seem to get it to read AFRs that match what the Logworks LC-1 software is reading (it's not a little bit off... it's WAY off... like the Logworks is reading 14 and the EMU is reading 6...) Does anyone know what settings to use in the EMU config? Argh!
Old Sep 27, 2006 | 02:36 AM
mikeschaefer's Avatar
I wanna rock! Rock!
yeah grab one of mazdamaniac's maps or search his posts, he made a comment about setting the voltage range of the AFR gauge in the EMU so it displays properly
I don't have the right answer on me right now though, sorry.
Thanks for posting this.. coincidentally I was reading the LC-1 installation instructions yesterday because I got bored. I'm probably going to order it and the gauge right before I get home!
Old Sep 27, 2006 | 11:41 AM
kenkamm's Avatar
Wow. I'm an idiot. Thanks for the help. I failed to coordinate the settings of the LC-1 and the EMU. I won't tell you what I was doing wrong, because I don't want to embarrass myself further.
Old Sep 28, 2006 | 05:59 AM
kenkamm's Avatar
Got it working. Thanks again!
Old Nov 13, 2006 | 09:28 PM
I wanna rock! Rock!
Originally Posted by GTAW
What analog output are you using? Since there are two, the Yellow and Brown.....you need to configure the analog ouput your using in the LC-1 to match the EMU. If you used the Brown wire.....
...using the supplied cable connect to the 2.5mm stereo output from the LC-1/XD-1 and the serial/usb to a laptop. Then, with the LM Programmer (the LC-1 comes with this CD) click on analog ouput 2 and set the voltage from 0-5v and the AFR from 10-20 and click program. Take the same settings, being the AFR, and input them into the EMU under "Front Panel" in the EMU under option 2, pick A/F meter then other and finally the AFR settings, such as 10 and 20. Now, if you used the yellow, just program the analog output 1.
I can't emphasize this enough! I'd read this thread 2, maybe 3 times before getting my LC-1/XD-16 and I still forgot to program the LC-1 and pulled my hair out wondering why the readings on the EMU were incorrect.
Old Nov 14, 2006 | 10:05 AM
kenkamm's Avatar
Version 2.0 of the EMU software now has the Innovate as an option in the drop down list!
Old Nov 14, 2006 | 11:37 AM
dgrx8's Avatar
FN GR8
those of you that have this installed...
can you post your tuning results! i'm sure lots will be interested now that there are options from racing beat, cobb, & several other tuners.
thanks
rx8guy86
9
Mar 29, 2007 08:50 PM
