syn oil how many miles?
Old Sep 23, 2006 | 02:23 PM
Exclamation syn oil miles and usage?[/B]
wondering how many are using syn oil and how many miles on you car?
i will go first.
royal purple 54k miles.
beers [/B]
Old Sep 23, 2006 | 02:48 PM
StealthTL's Avatar
Metatron
I'm next.....
Esso XD3, pao, 0w30.
32,000 miles.
S
Old Sep 23, 2006 | 03:19 PM
dillsrotary's Avatar
jersey fresh
royal purple
10,000 miles
27,000 total on car (don't know what previous owner used)
Old Sep 23, 2006 | 07:20 PM
RP about 12000 miles
Between that was Quaker State Advance Q, Castrol Syntec.
my baby just reach 19000 miles couple days ago.
Old Sep 23, 2006 | 08:17 PM
TheDosDog's Avatar
Recovered Modaholic
Red Line 5w30 for the last 5k. The first 48k on Castrol GTX.
Old Sep 23, 2006 | 09:13 PM
foo77's Avatar
4th batch : Apr 03'
Idemitsu fully synthetic 5W40 from 5K to 10K than change to Trust F2 for rotary fully synthetic 15W50 from 10K to 45K and change back to Idemitsu fully synthetic 5W40 till now 48K
Old Sep 24, 2006 | 12:54 AM
alchemist's Avatar
13k miles. Royal purple for last 6k.
Old Sep 24, 2006 | 12:59 AM
MazdaManiac's Avatar
41k of the 42k on the first engine - Mobil 1.
2k on the new (5k) motor with RP.
Old Sep 24, 2006 | 01:03 AM
Raptor2k's Avatar
Club Marbles Member
Why did you need a new motor?
Old Sep 24, 2006 | 01:17 AM
9G Redline's Avatar
Trolling since 2004
First 35K was whatever the dealer wanted to give me. The crappy Motorcraft stuff. I would add Mobil clean 5000 when it was needed. For the past 15k it's been Royal Purple and shall always be until I have a reason to switch. 50k in 2 yrs and 5 months.
Old Sep 24, 2006 | 01:35 AM
takahashi's Avatar
Only for first 5000km when the official Mazda engine oil was not available. Did not feel the any different and the first 5000km was not driven hard.
The Syn was Castro R 5W30.
Mazda rotary oil is mineral Castrol 5W30
I am ok for any oil being use.
I am changing over every 2000km or every 2 track days, so it is not matter whoever oil I use, as long as it is relatively new.
Old Sep 24, 2006 | 01:42 AM
Ike's Avatar
Ike
Blue By You
Mobil 1 for 22k miles, woooooo!
Old Sep 24, 2006 | 01:51 AM
uh,
which car????
Old Sep 24, 2006 | 02:08 AM
timbo's Avatar
rock-->o<--hard place
I've sold mine, but apart from the first 10,000k, when there was no MRO available from dealers, it was Mobil1. For the remaining 55,000k it was all mineral (MRO). I also change oil & filter every 5,000k
Old Sep 24, 2006 | 02:11 AM
BoosTED's Avatar
Amsoil 5w30 for the last 11,000 miles.
I debated between RP, Redline, Syntec, and Amsoil before choosing Amsoil.
Between RP and Amsoil the decision breaker was I had easier access to Amsoil since I can order it by the case and not wonder if it will be there when I need it. RP sells out fast at the Napa auto parts stores around me...
Castrol GTX (non-synth) 5w20 before that for 8,000 miles.
Total miles on car 19,000.
Old Sep 24, 2006 | 02:19 AM
jeffe19007's Avatar
Amsoil 5w20 for the last 5,000 miles of the 15,000 total. Change oil every 3,000 miles, so the oil may be getting to be all synthetic with the next change. Yeah, I know, expensive policy, but cheap insurance at this point.
Just went through the recall with flying colors, not even a plug change.
I may go to RP for it's availabilty and maybe a heavier weight such as 5w30 the international markets use.
Castol GTX 5w20 for the first 10,000.
Old Sep 24, 2006 | 07:25 AM
because his turbo said so ......
Look for his post about it. I was pretty suprise that he can go home with only 1 Rotor running !
Old Sep 24, 2006 | 07:51 AM
Raptor75's Avatar
Anyone hear of any engine tear downs after using syn and what did it look like? Especially RP.
expo1's Avatar
He's as bad as Can
75,000 miles RP 5w 30 since 70,000. Pre-mix also since about 70,000
Old Sep 24, 2006 | 09:59 AM
25k castrol 5w20
Old Sep 24, 2006 | 11:13 AM
Silver_Surfer's Avatar
I4NI
Almost 15,000- syn blend.
Old Sep 24, 2006 | 11:19 AM
mysql101's Avatar
Over a year ago I used synthetic for 3k miles then went back to dino oil. I didn't see any improvement with the car and wanted to make sure I didn't **** off Mazda (just in case).
Because of the turbo, I just put (in this morning) in 5 quarts of RP 10w30, and plan on staying with RP synthetic from now on.
Old Sep 24, 2006 | 12:14 PM
More like "because the local gasoline said so"!
117°F heat + 91 octane + high altitude + several minutes of constant boost on a mountain climb = PING!
The Renesis is a tough beast.
Old Sep 24, 2006 | 12:50 PM
Renesis is the weakest link !
We should all go piston and make it PX-8 !!!!!!!!!
NOT !!!!
Rotary ownZ !!!!!!!
You can say that, but I dont think the engine would *PING* if its N/A :P so yeah so it should be
gas + heat + high Altitude + *turbo boost* = Ping, one rotor go home :P
Old Sep 24, 2006 | 04:06 PM
Chamberlin's Avatar
2005 Ti Gray RX-8 - SOLD
Just switched to Penzoil Platinum 'full' Synthetic 10W30 at 33K. Stopped pre-mixing after the recall flash.
No clue what the previous owner had been running in this 2005 RX-8. Got only about 250 miles on the oil so far Since the recall flash, RP in the tran and diff, new plugs last weekend, this thing is really running great. Couple more oil changes and most of the dino will be gone!
-C
