increased tail smoot post recall
Old Sep 21, 2006 | 10:38 PM
turbodiesel_1's Avatar
I have 2005 MT with 1600 miles took in for recall yesterday had cat checked ok, updated PCM, replaced 2 leading plugs car drove fine before and I can't notice any difference now except for significant increase in tail pipe smoot. I had hardly any smoot before the updated flash. What could this mean?
Old Sep 21, 2006 | 10:45 PM
dillsrotary's Avatar
jersey fresh
the recall increases the amount of oil used by the oil meter, that smoot is just the more oil burning off.
Old Sep 21, 2006 | 10:50 PM
Its time to switch to clean burning Full Synthetic Royal Purple Baby !
Old Sep 22, 2006 | 02:36 AM
so in one day you drove it enough to notice a difference in smoot????
right!
Old Sep 22, 2006 | 06:05 PM
yes, drove it 130 miles averaging 75mph. I've done the same trip before but not nearly as much smoot. I understand there is more oil being consumed with the new flash, but the consensus on this forum in the past has been that the smoot is from a rich fuel mixture. Could this new T flash dictate an even richer fuel map?
Old Sep 23, 2006 | 02:10 AM
130 miles is not enough to judge imho. if you just had it flashed the ecu is still adjusting... the idle does not even stabilze for several drive cycles....
if you want to know.... clean the tips.... really good. put 1k miles on the car and decide...
btw, smoot is the combo of rich afr and oil... 75 mph still stay at stoich... at cruise... 76 gets you rich... this is with the s flash...
Old Sep 23, 2006 | 08:47 AM
So nobody knows if the new T flash has a richer fuel map?
Old Sep 23, 2006 | 02:25 PM
i can tell you the t is the epa version of the s flash, and it does not run any richer...
Old Sep 23, 2006 | 04:39 PM
what does epa version mean?
Old Sep 23, 2006 | 06:23 PM
enviormental protection agency.
Old Sep 23, 2006 | 06:33 PM
otherside's Avatar
I dont care...
What the hell is smoot? Do you mean soot?
Smoot= a unit of measure
Soot= carbon deposits
Old Sep 23, 2006 | 06:35 PM
smoot is the nick name for the oil / unburnt fuel mix on the tail pipes.
not sure how it started, but that is what it is here.
Old Sep 24, 2006 | 07:44 PM
Easy_E1's Avatar
I was going to see how long this SMOOT thread went. LMAO!
call it what you want,,,,, I call it SOOT.
Old Sep 24, 2006 | 08:22 PM
that might be correct if it was carbon... maybe ooooooot is the most correct...
Old Sep 25, 2006 | 12:44 AM
MazdaManiac's Avatar
Maybe it should be called "sloot".
"Smoil"?
I just call it spooge...
Old Sep 25, 2006 | 01:38 AM
"Smoil"?
smoil works... spooge is what you get after your avatar..
Old Sep 25, 2006 | 02:47 AM
I thought that was "spunk"?
Old Sep 25, 2006 | 02:52 AM
uh,
white chocolate... bartender speak....
