What does a slipping clutch feel like?
Old Sep 21, 2006 | 10:20 PM
Captain Amazing's Avatar
Old Sep 21, 2006 | 10:26 PM
Like a slipping transmission.
Usually it's hard to get into gear.
Old Sep 21, 2006 | 10:28 PM
LiveBlues's Avatar
When you hit the gas, and you see the tach rising a little faster than you would expect, but the car isn't accelerating like it should.
Old Sep 21, 2006 | 10:29 PM
Ok, thanks. What does it mean then when I shift into second and as I release the clutch it kind of shudders as I am applying the gas? Is it normal? It does not happen in any other gears.
Old Sep 21, 2006 | 10:34 PM
ken-x8's Avatar
Drive up a hill in a lower gear than you might usually use. Jab the clutch and note what happens to the rpm.
If the clutch is OK, the rpm will come right back to where it was. If it's slipping, it won't or (if it's just starting to slip) it will take a few seconds to come back.
If it feels like a slipping transmission (like Razz1 says) in normal driving, it's pretty close to blowing.
Ken
Old Sep 21, 2006 | 10:43 PM
This only happens once in awhile too.
Old Sep 21, 2006 | 10:47 PM
Rootski's Avatar
DGAF
It's kind of like when you feather the clutch yourself.
Old Sep 22, 2006 | 12:09 AM
Stavesacre21's Avatar
1.21 Jiggawatts
as others have said, it's very similar to feathering the clucth. by definition of what a clutch is, its a means at which 2 rotating surfaces come togehter. As you might imagine, this means that there isn't a connection between the 2. The car will feel like it's responding to the gas, but not very strongly, if any. Depending on the degree of wear, it can vary from starting to simply slip on occasion of intial engagement to almost seeming like your not even in gear. When it gets bad enough...you'll be in gear, and the RPM's are gonna rev like yur in neutral.
It's pretty hard to miss when you mash on the gas and then suddenly the clutch breaks away and the RPMS run way up without a huge gain in speed.
Old Sep 22, 2006 | 05:46 AM
dtorre's Avatar
Ultimate ****** Goderator
I had my clutch go out on me after 6K miles lol...that was fun...I was parked at a steep hill with tons of traffic behind me...tried to rev to 3k to get enough go power...slapped it in gear car just revved and I rolled back.....embarrasing... =)
Old Sep 22, 2006 | 08:43 AM
TomAssBender's Avatar
Skeet skeet skeet
I think this is normal. I have found (and other on this borad I believe) that the revs take a little longer to fall down to where they should be for second gear, so that when you engage the clutch, the RPMs are a little too high and it gives you a little shudder. Try holding the clutch in a little longer and making sure the RPMs drop to the right speed (around 1k less than where you were at), that works for me.
Old Sep 23, 2006 | 06:03 AM
juikster's Avatar
Im 8 drifting on a budget
could be your clutch plate and clutch disc is fryed from riding the clutch pedal constantly...just a guess...
Old Sep 23, 2006 | 02:35 PM
yamajj's Avatar
it feels great on an r6. downshift, let out clutch and everything is good.
yamajj
Old Sep 23, 2006 | 06:58 PM
Fishey's Avatar
Like a slipping clutch!.... DUH!!!
GO TEAM GO!
iphil
Sep 21, 2015 10:49 PM
djp6783
Sep 19, 2015 12:12 PM
Frosty8
Sep 11, 2015 10:27 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
