A/C blows HOT after recall
Old Sep 21, 2006 | 02:08 PM
WikkedOne's Avatar
Deals on wheels
Hey guys.. i've searched around a bit for info about this I'm sure there is info about it but I couldn't find it.. It's probably deep in that 45 page recall thread so I'm going to post MY findings.. sorry if it's a repost
well I got my recall letter a few days ago.. and I wasn't having any problems at all so I decided I'd take it in just in case.. took about 2 hours and everything was fine... on my way home I noticed that my car was letting some warm air out of the vents when it was switched to off and the temp was on the coldest setting.. it always did this except when i had the **** to cold it would be cool air..
Now when i try to turn the AC on all I get is HOT air.. I can kinda trick it to being cold by turning the temp to hottest and waiting 5 secs and then turning it all the way to coldest.. then it will blow cold air.. but if i move it one click warmer it goes surface of the sun hot again. I know this is because of the recall because it worked great untill the drive home from the recall..
I'm taking it back in but I just had to rant a little bit and hope that you guys could give me a quick fix so I wouldn't have to waste another hour or 2 of my life...
Old Sep 21, 2006 | 05:46 PM
dillsrotary's Avatar
jersey fresh
theres a tsb for that, same thing happened to me, bring it to the dealer its an under warranty fix for free.
Old Sep 21, 2006 | 05:52 PM
otherside's Avatar
I dont care...
It has nothing to do with the recall...Could be related to the TSB or we have also replaced some heater control assemblies for the same thing. Wiggle the temp control **** back and forth and see if it changes. If so, thats what it is.
Old Sep 21, 2006 | 07:37 PM
jersey fresh
chances are you'll need this:
http://www.finishlineperformance.com.../pdf/03-28.pdf
here's the list of all of them for the future too:
http://www.finishlineperformance.com...ins_index.html
same thing happened to me (and others i remember giving them this same link), its just random that it happened when you went in for the recall work, no worries.
Old Sep 21, 2006 | 07:57 PM
Tamas's Avatar
Registered Lunatic
Following the recall yesterday, today I noticed that I have the same problem (i.e. A/C blows warm air after recall).
Will test it a bit more but chances are I have to take it back to fix it, because something was fubared.
The irony is that I got to go back for the same dial assembly like in that TSB anyway, because mine needs to be replaced due to a cracked defrost button. I thought that it's interesting that someone else has the same A/C issue right after the recall...
Old Sep 24, 2006 | 08:19 AM
Its not really about the recall. Your A.C controls are going bad.
I've been living with this *sometimes heat comes out* problem for the whole summer, I just got it replaced by the dealer last week.
Just tell your dealer *A/C blows hot air when the **** is on the cold side, and cold air when the **** is on the hot side* , they will replace the whole thing for you.
Old Sep 24, 2006 | 09:34 AM
WikkedOne's Avatar
Deals on wheels
Thats not what it's doing. It blows hot ALL THE TIME. when the **** is on either side. I have gotten it to blow cold once, but thats after i played with the **** for the entire drive home. When i got it to do that.. i turned it 2 clickes warmer and it got blazing hot again. I havent gotten it to do it since.
It just seems too odd that the **** got "broken" while it was in getting the recall done.. because it was fine on the drive there and not fine on the drive home...
I'm taking it back in tomorrow and ask that they reflash it or check that a conneciton somewhere came loose or something.. i don't know but something got boogered up.
Tamas had the same thing happen to him.. Do you have any updates Tamas?
Old Sep 24, 2006 | 10:26 AM
Hej's Avatar
Hej
Reading the other comments, it seems like this is probably not the case, particularly since you said you did get it to blow cold once. Last summer I had a shop do some work on my truck, and afterwards I noticed that my A/C wasn't working. They simply forgot to reconnect the power cables to the A/C compressor when they were finished with my truck. Have you peeked under your hood and had a look at them?
Old Sep 25, 2006 | 05:12 PM
I had the same problem excat problem ! its just that I tried to turn it too much and it came to the point that most *of the time* would be : "Cold on hot side, hot on cold side"
Temp solution would be, if you want icy cold air, turn the **** to the cold side, hold the lower left edge of the **** down HARD for a while. and DONT move it EVER. It should stay cold.
You still gotta get the dealer to replace the whole thing tho. not just the ****, the WHOLE thing.
At first I thought Im just one of the unlucky one .... but I guess sooner or later there will be a new tsb for this.
Old Sep 25, 2006 | 05:50 PM
jersey fresh
nycgps is right, the dealer will replace the whole unit. the reason its set on either always cold or always hot is the **** doesn't register anymore (or only registers sometimes.) if you look under the dash from the driver's side and move the temp **** you can view the plastic arm that turns from hot to cold, and yours is stuck. This happened to me, stuck on cold, in the winter in NJ. Just remember the dealer might not have the part in stock, it took a week to get my new unit in, head to the dealer, sooner the better.
Old Sep 25, 2006 | 05:55 PM
Tamas's Avatar
Registered Lunatic
It's somewhat better now but still seems to be worse than before the recall. As I said, I'll get the three dials (one assembly) replaced anyway due to the cracked button, so I'll see if that fixes the problem. Or maybe it'll get back to normal by itself since it's improving a bit...
Old Sep 25, 2006 | 06:38 PM
RotorMotor's Avatar
Senior Member
Have other people been having **** breakage too? My temperature **** broke recently. Is that TSB saying that I should get my **** replaced for free? I called my dealership about it and they were going to charge me $58 for a new ****!!!!
Old Oct 3, 2006 | 12:31 AM
SilverMiata's Avatar
2004 GT 6-speed
Broken AC Temp Control ****
I just replaced a broken Temp Control **** in my wife's RX-8. I thought maybe it broke at a carwash, but now I'm thinking it might have been broken by the dealer during the recall.
Does the recall require removal of the HVAC or control *****?
Also, considering the **** design has changed, with a beefed up attachment ring (see pictures), should Mazda pay for the replacement ****? You can see where the old **** broke (right picture).
Finally Bay Area Mazda Owners: I got the **** from Fremont Mazda for $30.31. This is after they quoted me $44. I showed them what Trussville sells them for ($30.31) and they matched the price.
Attached Thumbnails A/C blows HOT after recall-knobnew.jpg   A/C blows HOT after recall-knobold.jpg
Old Oct 3, 2006 | 06:43 AM
You know they extend the warranty to 60K miles right ?
you might already pass that but ..... if you're still within the warranty period. you might want to ask your dealer to replace the whole thing. It just gonna take them less than 30 mins. but remember most people does not have this part in stock, so they gotta order them, usually take about a week or 2.
Old Oct 3, 2006 | 11:45 AM
lonecow's Avatar
AC Blows Cold while driving, Hot air at idle
The Mazda dealership can't find anything wrong with my 2005. It blows out cold air fine while the car is moving but when it comes to a stop or idle, it blows hot air. They say this is normal. I don't think so. I had my engine replaced at 3,000 miles and it did fine prior to this. What could they have screwed up during the engine replacement?
Old Oct 3, 2006 | 12:28 PM
delete your other thread.
what do you mean it blows out air when moving and hot air when it stops.
is it with AC on or off ?
Old Oct 4, 2006 | 06:53 AM
lonecow's Avatar
AC problems
The AC is ON and it blows cold while driving. When I am stopped at a red light for a minute or two or stuck in traffic, it blows hot air. Not just a less colder air, but HOT air like the unit has totally shut off.
theblinkof
Oct 4, 2023 05:24 PM
nadodave
Aug 28, 2019 05:55 AM
XianUnix
Sep 29, 2015 03:48 PM
pjwermuth
Sep 28, 2015 11:36 PM
