clutch instillation
Old Sep 21, 2006 | 12:09 AM
suzuki_rider22's Avatar
adrenline junkie
clutch instillation
has anyone installed their own clutch? if so how complicated was it, how much time did it take, and what tools do you need?
Old Sep 21, 2006 | 12:33 AM
BoosTED's Avatar
It requires:
1. taking the exhaust off
2. taking the shifter out
3. supporting the rear diff with a jack
4. taking the power plant frame off (surrounds the drive shaft and holds the transmission in place).
5. taking the drive shaft off (being very careful not to scratch it if it is the carbon fiber one)
6. disconnecting all the wires from the transmission
7. taking the transmission out
8. uninstalling the clutch
9. resurfacing the flywheel using 80 or 100 grit sandpaper in a circular motion to get any ridges out.
10. uninstalling the throwout bearing
11. reinstalling the clutch using the clutch allignment tool
12. reinstalling the throwout bearing
13. reinstalling the transmission, driveshaft, ppf (making sure to use the torque specs and allignment specs for the transmission, ppl, and driveshaft) If this is not done the potential for damage is high and dangereous...
14. top off the transmission as it will leak some gear lube when pulling it down.
15. reinstall shifter
That being said it isn't too bad.
Old Sep 21, 2006 | 12:36 AM
BoosTED's Avatar
Requires 4 jack stands, 80 or 100 grit sandpaper, clutch allignment tool, shop manual, torque wrench, various standard tools (sockets, wrenches, extensions, exhaust hanger removal tool)
2 jacks
Old Sep 21, 2006 | 12:38 AM
BoosTED's Avatar
Make sure and disconnect the negative battery terminal.
If the car falls off of a jackstand or jack it could deploy the airbags.
Old Sep 29, 2006 | 10:43 PM
epitrochoid's Avatar
Riot Controller
or you know...it could just...kill you?
Old Sep 30, 2006 | 04:23 AM
BoosTED's Avatar
Yep.
That would be bad, really bad.
Old Sep 30, 2006 | 10:34 AM
silverwolf's Avatar
huh what? no.
search....
Old Oct 5, 2006 | 05:59 PM
RXPower's Avatar
Take the flywheel in to be resurfaced, ground not lathe cut. You could have issues with the operation of the clutch if it's not perfectly even. This includes bad pull down, uneven wear, hot spots on the flywheel. not releasing, etc. It'll cost around $20
Old Oct 5, 2006 | 06:49 PM
rxeightr's Avatar
M0D Squad -charter member
Just put in a lightweight flywheel while you are at it. Best mod I've done yet.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
mattymack
Sep 6, 2015 10:33 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
