Couple questions
Old Sep 18, 2006 | 09:00 PM
mazda8guy's Avatar
Couple questions
I have an 04 and there is a bad vibration at idle. Goes away with a little throttle but returns when it idles down again.
Also there is a really load click when I turn the key off and on without the rotary running. Any ideas what that is?
Thanks and I did try and search but it brought up tons of results. I guess I suck at searching.
Old Sep 18, 2006 | 09:43 PM
fullsmoke's Avatar
Anatomy of a corner...
How bad is "bad"? We have a sports car, it's normal for the 8 to have a rougher idle. Where is the click coming from? I get clicks from the engine bay--sounds like maybe some syncro motors checking themselves (so, it is normal).
FS
Old Sep 18, 2006 | 10:05 PM
mazda8guy's Avatar
Its not a rough idle but a vibration. It shakes the shifter back and forth and you can see it. I was just looking through he tsb's and I think I found the problem. Cracked engine mount.
Going for the recall next Monday so I will get it looked at then.
Ya I guess I should have said the engine bay. When the key is cycled on and off the is a load "click".
Old Sep 18, 2006 | 10:13 PM
dillsrotary's Avatar
jersey fresh
yeah, I usually check the tsb's first because chances are (especially with an 04) its on that list. My money is on your engine mount, have the dealer take a look.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yankeepicker
Sep 11, 2015 05:42 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
