Fender Vent DIY
Old Sep 18, 2006 | 07:29 PM
Tayler's Avatar
Fender Vent DIY
After staring at a foreign language for a couple hours I stumbled across a really good DIY mod. Figured I should share...
(Direct translation from babelfish adds a little comedy)
It is processing the fender grille.
Grille under photograph to grille above
It keeps cutting with the cutter knife.
Patience needs suitable, (the ^^)
Way the finger is not flown,!
(Paying attention on self responsibility.)
The part, with left and right, is about 1500 Yen.
With such feeling, the ちび ちび cutting
It goes.
If there is a compressor, with the air saw
It can make easy, however it is, don't you think? the ぇ.
Furthermore, it finishes to here.
Before painting, already just a little it is to be cut off, does.
Temporarily, time it is required.
Headache may do,
When it paints, such feeling?
Already, just a little, the finish is bad, don't you think? is.
The mark of the paper coming out, it increases.
(Also the photograph is bad, is.)
It is halfway lapse.
Because there are left and right, it is serious.
After, of the net is not thought, as for the て.
When you complete, such feeling
Paper in 400.600.1000 turn
Applying correcting, re-paint
Brilliant black for ホルツマツダ car
As for wire net, at foam/home center,
One for screen door of 10 cm 100 Yen
Net of aluminum
The reverse side, turning back,
Stopping at the hot bond
Completion!
When you install, it becomes such feeling.
Because the inside, is completely visible, unless it paints in black, (the ^ ^)
Old Sep 18, 2006 | 07:33 PM
dillsrotary's Avatar
jersey fresh
this thread is useless without pics
Old Sep 18, 2006 | 07:34 PM
Tayler's Avatar
Pictures...
Attached Thumbnails Fender Vent DIY-1.jpg   Fender Vent DIY-2.jpg   Fender Vent DIY-3.jpg
Old Sep 18, 2006 | 07:39 PM
Tayler's Avatar
More...
(Can't wait a few seconds for pictures? Sheesh...)
Old Sep 18, 2006 | 07:45 PM
DrDiaboloco's Avatar
Pining for the Fjords
I disagree... The translation is priceless.
Old Sep 18, 2006 | 07:54 PM
Tamas's Avatar
Registered Lunatic
All your base are belong to us...
Old Sep 18, 2006 | 09:12 PM
NgoRX8's Avatar
i wanted to try this. scary. good job.
Old Sep 18, 2006 | 09:35 PM
jersey fresh
Fixed!
{not to sure}
It goes.
Old Sep 18, 2006 | 09:36 PM
jersey fresh
Headache may do,
Old Sep 18, 2006 | 09:38 PM
jersey fresh
Net of aluminum
Completion!
Old Sep 18, 2006 | 09:41 PM
jersey fresh
i'm just having fun taylor, you did take the time to translate everything, good orginal post and good mod.
Old Sep 18, 2006 | 11:20 PM
DOMINION's Avatar
I don't buy Kool-Aid
You do know they will still be useless unless you cut the plastic behind the front wheels
Old Sep 18, 2006 | 11:32 PM
msrecant's Avatar
Hubble has been saved!
And all this effort ends up accomplishing what?
Old Sep 19, 2006 | 12:23 AM
Kel Rx8's Avatar
if your not 1st your last
dillsrotary ure funny
Old Sep 19, 2006 | 02:25 AM
DOMINION's Avatar
Well if you cut lengthwise split/strips in the plastic behine the front wheels then they will let air flow out.
Old Sep 19, 2006 | 07:05 AM
scsi's Avatar
they look nicer
Old Sep 19, 2006 | 09:20 AM
zenmoused's Avatar
the stig is my hero
I would say there's a couple ounces of weight reduction. For that, I shall do this mod. (I wonder what kind of paint he used?)
Old Sep 19, 2006 | 04:05 PM
Tayler's Avatar
Good one dills! Oh don't sweat it, I didn't translate anything. I just plugged the address into a language translator and that was what popped out.
I'm not saying this is a functional mod, I just can't stand how the side vents look. Not a fan of plastic...
Old Sep 19, 2006 | 04:19 PM
jersey fresh
plus it will be a little cure for the mod bug, purely visual though.
Old Sep 20, 2006 | 09:26 AM
PRLegend's Avatar
Smile
or just touch it up like I did. Simple then that it cant get.
Old Sep 20, 2006 | 10:40 AM
dam, this job would take a whole day to do!
Old Sep 20, 2006 | 10:51 AM
darkducati's Avatar
No, it's All your piston are belong to us.
Old Oct 6, 2006 | 08:00 PM
EZZY's Avatar
cry me a river...
good work.
thats exactly what i have done to mine..
Old Oct 7, 2006 | 12:59 PM
DOMINION's Avatar
Or longer
Old Oct 7, 2006 | 06:04 PM
rx8power's Avatar
Boricua Hasta La Muerte
Thumbs up
Did Mine today, took all day since you gotta wait for paint to dry, but the results are...., well he are the pics. I took the last picture with the flash on, so you can see that I did not use a grill but painted the inside part of the fender wall, plus I painted them in low gloss black, instead of the glossy black. I put a grill on the first one but took it off because didn't like the look.
Enjoy,
RX8Power
Attached Thumbnails Fender Vent DIY-100_2312.jpg   Fender Vent DIY-100_2313.jpg   Fender Vent DIY-100_2316.jpg
