Recall "T" Flash and Roughness Under Deceleration
Old Sep 18, 2006 | 10:31 AM
brillo's Avatar
Go Texas Longhorns!
After getting the recall done I noticed that like the S flash, the new T flash causes a roughness at deceleration due to the RPM’s falling down to what appears to be about 750. This seems to happen whether I am in gear or in netural.
With the S flash, this went away after a few days of driving. After over a week of driving, my car still seems to be rough during deceleration.
The good news is that the idle is much better with the A/C on once the idle comes back up after deceleration.
Anyone else notice this? Has anyone who has gotten the recall flash had the same experience? Did it go away for you after a few drive cycles?
Old Sep 18, 2006 | 12:05 PM
hmmm, very interesting. I'm getting my recall done on Friday and I'll report back with any findings.
Old Sep 18, 2006 | 01:04 PM
late8's Avatar
late8
I had my 8 in for the recall two weeks ago and I've got no problems with roughness in decelaration. Mines an '06 mt.
Old Sep 18, 2006 | 02:25 PM
chr1s's Avatar
pwn*
hey brillo.
I don't have any issues and I had the S for a month or so, then got upgraded to the T a 2 weeks ago.
Cars running great. 100%
Old Sep 18, 2006 | 03:37 PM
kwescott's Avatar
One ball, corner pocket
I havent done a single reflash since I purchased my car in 04...so I have no idea which flash I have. One thing though, after the installation of a flywheel and pulleys, my RPM drop to 750, sometime a bit closer to 700. I've even had the engine stall a couple times. I know what you're talking about with roughness. I'm concerned now...do you mean that your engine didn't used to idle at 750, that it dropped with this new flash. If so, I may be in for some trouble....especially since I have close to 60K miles on the car and am outside of my warranty.
Old Sep 18, 2006 | 03:58 PM
olddragger's Avatar
yea I have noticed that also--almost like the neutral switch is gone. Used to push in the clutch/coast and the car would settle at 1K--not anymore.
olddragger
Old Sep 18, 2006 | 04:16 PM
brillo's Avatar
Go Texas Longhorns!
hmm, interesting. I have had the RPM's surge before up, which was a sign of the neutral switch, but if that is also a sign, I might have to take it into the dealer now.
my engine does idle at the 950 mark, its just when I put the clutch in that it drops down real low before it settles into idle.
Old Sep 18, 2006 | 10:20 PM
get it with the s flash. but i also notice my idle does not drop till i stop...
i will live with that shudder as opposed to the ac shudder.
Old Sep 18, 2006 | 10:51 PM
dang, you should've done the R flash recall while you have a chance.
From what I've read, if you got your 8 in early 04. you probalby have the L flash ! Which is the stupidest flash for the car.
Hmm , maybe its time to get your engine check. Because I think 750 idle speed is WAY too low(typical should be around 810~)
Old Sep 18, 2006 | 11:01 PM
brillo,
clear pm. tard!
Old Sep 22, 2006 | 06:03 PM
Any time you clear the ECU you may get this and a rough idle until you drive a few cycles.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
