Where does your clutch safety switch trip?
Old Sep 12, 2006 | 05:27 PM
corners's Avatar
An RX ate my baby
I had my clutch pedal replaced last week for a squeak. The squeak is gone and the clutch works nicely, although I noticed that it has to be held right against the floor for the car to crank. I never noticed this before, although I've only had the car for a month.
How high off the floor can you hold your clutch pedal before the starter interlock won't allow the car to crank?
Old Sep 12, 2006 | 06:20 PM
dunno about yours. but mine, gotta floor the clutch before it would start.
Old Sep 12, 2006 | 06:46 PM
otherside's Avatar
I dont care...
Right to the floor. Normal condition.
Old Sep 13, 2006 | 08:38 AM
dgrx8's Avatar
FN GR8
i'm surprised they gave you a brand new clutch... i went in for a squeaky one as well but they gave me the runaround & said they couldn't hear anything when i picked it up...
Old Oct 18, 2006 | 02:57 PM
Philip_SA's Avatar
Rotary lover
to be honest, I think our South African market RX8's are different. I can start standing outside the car putting my hand through window.
Maybe it is disabled but not as far as I know, I think we dont have that function
Philip
Old Oct 18, 2006 | 03:02 PM
no dice's Avatar
I bomb atomically
if your switch is broken or stuck in, it will always start. That being said, you should lose cruise control too since it disables if the clutch is engaged.
My clutch must be floored before i can crank.
Old Oct 18, 2006 | 03:37 PM
Nubo's Avatar
Lubricious
I'd never thought to try anything but right to the floor.
Old Oct 18, 2006 | 03:44 PM
I think NA market 8 (or all stick shift) cars got this *safety feature* build in.
Old Oct 18, 2006 | 03:49 PM
StealthTL's Avatar
Metatron
Wink Adjust....
It's adjustable if it bugs you, it is the switch at the bottom of the clutch travel (obviously!) and has the black body/white plunger.
South African (and the rest of the civilized world) models would not have to push the clutch in to start - it is a legal thing in North America only, to prevent you running thru the garage wall, then suing Mazda. Purely lawyer-driven.
The clutch switch that disables cruise is an unrelated one, at the top of the clutch travel (duh!) with a red body/black plunger, also adjustable.
S
Old Oct 18, 2006 | 03:53 PM
After reading your post , Im thinking
I might be able to get the Remote start thing from Japan, and install it to my 8 ? Just need to disable(remove) the push in clutch to start car thing, right ?
Old Oct 18, 2006 | 04:11 PM
staticlag's Avatar
The Professor
seconded
Old Oct 18, 2006 | 04:13 PM
no dice's Avatar
I bomb atomically
at times when i get bored, ill crank my key and then push the clutch down. Its like having a push button start with a clutch!
Old Oct 18, 2006 | 04:22 PM
RedSheDevil's Avatar
.:. causing mischief
S
any chance this will bring the clutch closer to the seat? i'm only 5'2" and hate having to drive so close to the steering wheel in order to floor the clutch pedal.
Old Oct 18, 2006 | 04:31 PM
no dice's Avatar
I bomb atomically
Thats why you should always wear a set of these whenever you drive..
Old Oct 18, 2006 | 04:33 PM
OMG LOLZ!!!!
Jst4fun
Mar 5, 2021 07:16 PM
Digitz0070
Oct 7, 2015 12:43 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
