Wiring Diagram LC6
Old Sep 12, 2006 | 01:01 AM
gavinopoly's Avatar
Wiring Diagram LC6
Anyone know of a thread showing a wiring diagram for hooking up an LC6.
Gavin
Old Sep 12, 2006 | 01:24 AM
StealthTL's Avatar
Metatron
Arrow Not quite getting it.....
Could you be just a LITTLE more obtuse?
What the hell is an LC6.....a new Corvette motor?
S
Old Sep 12, 2006 | 02:13 AM
lesper4's Avatar
T-29 years and counting
come on stealth with 1800 + posts and you do not know what an LC6 is?! and he only has one post. It is very similar to the JL Audio Clean sweep. It is a signal processor for those cars that have highly intregrated stero systems such as the Bose in the RX-8. I know Audio Control has some wiring diagrams on theri website now sure hoe helpful they are. i will soon find out. You can connect the LC6 or LC6i into any amp in your system and the tap into that with the rest of your componets. If you have any questions i am sure Forbidden will be able to help you out. By the way Forbidden if you are out there where is the best price i can buy an LC6i mayeb you or local?
Old Sep 12, 2006 | 02:16 AM
S
dude,
like you are like stupid... i was sure it was the new vette motor, but i shut my pie hole....
i so hope this helps
Old Sep 12, 2006 | 02:17 AM
lesper4's Avatar
http://www.mobileaudiocontrol.com/de...17612&l1=17612
PRODUCT
http://www.mobileaudiocontrol.com/de...21366&l1=21366
WIRING DIAGRAMS
Old Sep 12, 2006 | 02:18 AM
posts dont matter age matters... i cant speak for stealth, but i was sure it was a vette motor...
i listen to xm to get good am radio... go figure..
Old Sep 12, 2006 | 01:18 PM
forbidden's Avatar
I am a CDN authorized dealer, your best bet is to find one locally.
As far as the install goes, is your vehicle a Blows or non-Blows system?
Old Sep 21, 2006 | 11:55 AM
gavinopoly's Avatar
LC6 wiring diagram
It is a Bose system. I was going to replace the Bose amp with the LC6. Put in a 500/1 JL Amp to run a 10" JL sub in a 4080 box and keep the stock components for now.
Old Sep 21, 2006 | 05:11 PM
jstkilntim's Avatar
resU deretsigeR
I assume you realize that you can't replace the Bose amp w/ an LC6. It is still needed to power the rear components & the signal for the fronts go through it.
Old Sep 21, 2006 | 06:52 PM
lesper4's Avatar
You tap into the stock amps to get a signal to the lc6 and then run that to your amplifers to run your subs, you will not replace anthing but instead be slicing subs into the setup.
Old Sep 22, 2006 | 09:13 PM
gavinopoly's Avatar
Lc6
Do you use the ground,power,remote wires from the Bose amp to feed the LC6. Or would you split the 12v 4 gage that I ran from the batter to feed the LC6 and the 500/1 JL amp.
Gavin
Old Sep 23, 2006 | 10:31 AM
jstkilntim's Avatar
resU deretsigeR
Gavin
Do not use the power & ground from the Bose amp. Since you have already ran power from the battery, use it. Be sure to fuse each component properly. Read the ground sticky for ideas on finding the best ground.
The LC6 can sense the audio signal & turn itself on without the remote in , but you may want to use it anyway to prevent it from turning off at low volumes, especially if you are tapped before the Bose amp. You will probably want to get this from the accessory plug in the console.
The LC6 also has a remote out that I would use to turn on your amp.
Old Sep 24, 2006 | 09:27 PM
gavinopoly's Avatar
Remote Wire
I ran a single remote wire from the fuse panel. I'm sure I can find a spot there to splice it in. Can this single remote wire be used for the LC6 and the 500/1 amp? I'm also looking for the black terminals that snap into the LC6. The seller on eBay didn't include these clips without my knowledge. Any chance on finding someone locally that has something that would fit or are these terminal clips hard to find?
Gavin
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
