High beam failure
Old Sep 8, 2006 | 10:53 PM
DarkBrew's Avatar
Extraordinary Engineering
High beam failure
Guessing game:
My high beams and daytime running lights are not working.
The blue high beam idiot light still works.
I checked the fuses and did a quick visual inspection of the relays. (all in place)
I find it hard to beleive that both high beam bulbs would fail at the same time since one is fairly new.
Anyone want to guess what's causing this?
Old Sep 8, 2006 | 11:09 PM
power spike maybe, but I dont really think so.
Or some water went into the compoments.
how old is your 8 ? ask your dealer to check it.
if your 8 is faily new. it should be covered under warranty.
Old Sep 9, 2006 | 02:08 AM
StealthTL's Avatar
Metatron
You're right....
You are correct, the chances of both hi-beam bulbs going at the same time are remote.
It would have to be the module that switches them.
There have been two instances I know of, of the DRL module quitting.
S
Old Sep 9, 2006 | 10:23 PM
Nubo's Avatar
Lubricious
You usually can't determine the health of a relay by visual check.
It's not unheard of for both bulbs to blow.
I don't like guessing. To find the answer you need to trace the circuit with a voltmeter or test light. Easy!
You've already replaced a HiBeam? Dang, those DRLs must be hard on 'em. But at least everyone is able to *cough* see your car in the daytime.
Old Nov 7, 2008 | 02:28 PM
RENESIS rotary's Avatar
i have a same problem. both high beam are not working, so i replaced them, and still nothing...??
Old Nov 9, 2008 | 11:36 AM
byez's Avatar
i have a same problem. both high beam are not working, so i replaced them, and it worked!
lucky me
check your bulbs
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Austin22
Sep 23, 2015 04:46 PM
