No Sound
Old Aug 31, 2006 | 12:32 PM
Paxhumas's Avatar
No Sound
Hello all i just bought a 2005 RX8 MT and i am loving it so far but the only problem i have is that the Radio doesn't work i have the 6 disc in dash cd changer and 9 speaker Bose system i can tell that it all works but there is just no sound and i can't figure it all out. I could take the car to a dealer and have them look at it but that is a 5 hour drive away and i can't get the time off to do it so i have to do it myself. So any help on this would be good i also would like to know if there is an amp and where it is cause there just might be a loose wire but i am afraid to take apart the dash without knowing where all the screws are and such so any help would be greatly appreciated.
Old Aug 31, 2006 | 12:41 PM
8is>enuff's Avatar
Bland
Start with the obvious.
Is the volume up?
Is mute on?
Old Aug 31, 2006 | 12:56 PM
jstkilntim's Avatar
resU deretsigeR
The main amp is under the rear deck. You can see it (and the plugs) from the trunk. The front door amps go through the rear amp also. Check your plugs & fuses.
Old Aug 31, 2006 | 01:10 PM
WikkedOne's Avatar
Deals on wheels
I'm going to have to go with jstkln on this one.. I'm not sure but I would look for the fuse that drives the bose amp (i'm not sure if it's the same one that does the head unit)
the main fuse box is near the hood / trunk release.. I don't know if there are any other fuses for it.. but thatd where I would start
Old Sep 1, 2006 | 02:07 AM
N rider89's Avatar
^NieL
i had this exact type of thing happen to me check the fuse box down by the pedals. one of my fuses blew and i lost sound. every thing ran fine but no sound. i replaced one fuse and it was fixed
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
