Defi gauges
Old Aug 30, 2006 | 08:22 PM
wen pin's Avatar
Defi gauges
Hi pple,
Thought of installing 3 defi gauges (just to look good in the interior) at Monster Garage! Cost slightly over 1k. Has anyone done so and any complications? Any advice will be greatly appreciated.
Thks
Old Aug 30, 2006 | 09:10 PM
watoke's Avatar
RX-8の魅力満載
Hi Wen Pin,
There wudn't be any complication. I have 6 defi gauges on my dash. So, what you think?
Old Aug 30, 2006 | 09:20 PM
wen pin's Avatar
Walau! 6 ah! U go tracking or wat! Where you had them installed?
Old Aug 30, 2006 | 11:55 PM
watoke's Avatar
RX-8の魅力満載
well, i used to go track when I was driving the DC5r.
I fixed it up also mainly for track (and deco lah), but apparently due to my work commiment and overseas assignment, i really finding hard to get time to go track. Hopefully, I can do it one of the day
Old Aug 31, 2006 | 12:00 AM
tan280's Avatar
orh jiao RX-8
Defi gauges.... damn zhun in measurements le... no harm fixing up there... at least we hv peace of mind of seeing there... not much complications.
Old Aug 31, 2006 | 12:06 AM
wen pin's Avatar
ok man... ...will get it fix soon...thks a mil guys...
Old Aug 31, 2006 | 02:25 AM
whitedragon's Avatar
Me thinking of it too. Do u guys put on the center of the dash? Btw which three is normally put? Oil temp,water temp, oil pressure? Will it void MM warranty? Thanks
Old Aug 31, 2006 | 02:46 AM
PitchBlaC's Avatar
I've got a question for those who fixed up the water temp and oil pressure. Do you think it is really necessary to fix these 2 gauges since the car already have them.
How much is the differences in reading between the stock gauges and defi. I would like to know. Thanks.
Old Aug 31, 2006 | 02:55 AM
wen pin's Avatar
Hi whitedragon,
The 3 gauges as you'd mentioned is the normal stuff if you dont intend to go tracking. Spoke to darren of MG. Says take half day job cos need to drain the original coolant and replace with another brand, Preston. Not sure if this is appropriate. Their current gauges come in amber red. I'm waiting for the latest type which comes in blue but a higher price. MG will revert when the stock arrives. As with the warranty nd to chk with MM.
Old Aug 31, 2006 | 03:09 AM
coupe07's Avatar
SC 300HP!!
Originally Posted by wen pin
Hi whitedragon,
hi wen pin, i think there is a misunderstanding. dun have to drain ur coolant. However note that ur coolant will leak due to the installation of the hose joint. Dun worry, on monster's end, they will top up for u.
Of cos, if u wan to change ur coolant, we are using prestone.
Old Aug 31, 2006 | 03:13 AM
wen pin's Avatar
PitchBlaC, It did occurred to me too as you rightly pointed out. I'm told defi reads more accurately than stock. I'm taking this with a pinch of salt tho. Only those who have installed can probably enlighten us. HELP!
Old Aug 31, 2006 | 04:09 AM
coupe07's Avatar
SC 300HP!!
do note that the blue face defis that u r toking abt only comes in 52mm. Primarily targeted for the US markets, it does not need a control unit to work. And it cannot connect to the defi link system....
Old Aug 31, 2006 | 06:01 AM
sandman369's Avatar
generally, those stock gauges are pretty useless. they are not designed to move over a range of values on normal operation conditions. broadly, by the time they move, it would have been too late. defi will give you actual readings and you can monitor and take preventive measures should "personal" thresholds are crossed.
Old Aug 31, 2006 | 06:02 AM
sandman369's Avatar
just to add that, in fact, any proper gauge will do the trick, not juz defi.
Old Aug 31, 2006 | 09:15 AM
PitchBlaC's Avatar
But how fast does the defi meter responds compared to the stock ones? And the differences in reading?
Old Aug 31, 2006 | 10:39 AM
jetblast's Avatar
vroom vroom
Cool
i couldn't agree better
defi will register readings a min or 2 from idle
under city driving conditions, e oil temp is about 90ish
while constant high revs above 6000 for 15min can push e temp to 115
defi will respond within seconds and during e cool down lap readings can drop to a 100 within a min and all these while e stock gauge stays put
if u tracked e gauges are good to have if u dun they are great center piece
Old Aug 31, 2006 | 11:07 AM
PitchBlaC's Avatar
Talking
Gee. Thanks for the info. Think I gonna strip out my stock meter and put a defi one in its place, if that can be done. Hee
Old Aug 31, 2006 | 11:16 AM
Rei's Avatar
Rei
White Rotary
Juz ran a search on the blue face defi gauge...looks damn cool...I think they will
suit bros wif winning blue 8 very well...
Juz 1 qns though...if the defi control link system cannot be used, how to
control the gauge to work...sorry to ask...dunno gauges very well...
Old Aug 31, 2006 | 09:00 PM
legendary's Avatar
I dont track but installed the gauges for the "look". Trust me, you wont regret !! Never fails to pump me up everytime I start the engine and the gauges rev up.... shiok .......
Old Aug 31, 2006 | 11:33 PM
sandman369's Avatar
according to the defi website, it's a direct link between sensor and gauge, and control functions are not available. unlike the BFs with defi control, for the blue gauges, you cant set the warning peak (electronically) nor can you record the readings. peak indication is set manually with the bezel (like a traditional dive watch).
i vaguely recalled someone mentioned before one can change the colour of the BFs (from red to white and vice-versa), not sure if blue is possible tho.
Old Sep 1, 2006 | 12:02 AM
Zero_Rotary's Avatar
Double 8
where can i get this info to change the backlight colour? i got the white lighted BFs ...i didnt know it can be changed to red?
thanks
Old Sep 1, 2006 | 01:06 AM
celeste84's Avatar
http://www.subaruclubsg.com/phpBB2/v...ic.php?t=47963
He is the want who do the conversion.
40 bucks for each gauges,
he is very good it in, and have a very good workmanship!!!
Old Sep 1, 2006 | 04:51 AM
Rei's Avatar
Rei
White Rotary
I c...thanks for the info...
Old Sep 1, 2006 | 05:35 AM
ml2spin's Avatar
Eh?? Defi BF gauges now come in Red, White and Blue.
Those blue ones running without link control are Blue racer gauges meant for US market.
Old Sep 1, 2006 | 10:43 AM
celeste84's Avatar
defi japan have officially release the blue defi bf which required the control unit. just like the red and white wants..
