Under Hood Cooling Options?
Old Aug 29, 2006 | 08:26 PM
DRKSYDE's Avatar
Vagitarian
OK so we all know that our under hood temps are really high... Don't have exact numbers but its warm.
Soo without major aerodynamic fabrication how to get cool outside air into the engine bay and then out with the hot air??
Has anyone thought about electric exhaust fans? I have two thoughts...
If the car has a new vented hood then place the exhaust fans directly below the new vents once the hood is closed.
The other option if you have a stock non vented hood... would be to place an exhaust fan on either side of the engine bay with a limited amount of piping throught the inner fender well and out of the fender vents.
Now I am no engineer and these are just a couple of quick ideas I thought might work. Anyone have any thoughts or insight?
Old Aug 29, 2006 | 09:04 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
I think the natural flow of the air would take the hot air out of the engine if you have a vented hood. DOn't think you would require a fan
Alternatively, driving without a hood also works.. hehe
Old Aug 29, 2006 | 09:35 PM
DRKSYDE's Avatar
Vagitarian
You would think so but I think it would help with the fans even more. LOL Without a hood yes... just make sure all the plastic engine pieces are off!
Old Aug 29, 2006 | 09:53 PM
Clavius's Avatar
Its all about Style...
I'm still surprised with the notority that the 8 and Rotory's have in general of being heat monsters that radiator companies havent jumped on board for development of a larger or more efficient one.
I seen a DIY for brake cooling vents the same idea or method I think could be led into the engine bay for additional cooling??
Old Sep 1, 2006 | 02:05 PM
Zero_Rotary's Avatar
Double 8
these are what i can think of that might reduce the heat:
oil coolers
high capacity radiator
mazsport's early fan kick off relays&sensor.
fan controllers
vented hood
low temp thermostat
engine oil viscosity
Old Sep 1, 2006 | 04:19 PM
Jax_RX8's Avatar
Got Another Rotary
I would not add a hood vent as you already have functional side vents (shine a flashlight through the holes on the back corners of the engine bay and look into the vents).
I would consider the Mazsport fan controller as it runs the radiator fans much more agressively to keep the engine (and engine bay) much cooler. Check out this link for details:
https://www.rx8club.com/showthread.p...5&page=1&pp=40
Old Sep 1, 2006 | 08:30 PM
Moonrover333's Avatar
My Goodness My Guinness
another cheaper option is raising the back of the hood by adding a spacer inbetween bolts and brackets
i like it personally
Old Sep 1, 2006 | 09:52 PM
Trekk's Avatar
Goat rider
I cut the vents bigger behind the oil cooler to allow the air to flow a little more easy. Might not do anything, but its was worth a shot and took a good 2-3min to do.
Old Sep 2, 2006 | 08:28 AM
DRKSYDE's Avatar
Vagitarian
These are all good suggestions.
I was just trying to see if anyone thought a couple more electric fans would assist in cooling even more on top of these sort of things.
Old Sep 2, 2006 | 10:28 AM
ddub's Avatar
always preoccupied.
And if you do it with just spacers/washers if you get in a head on collision the hood will be pushed through the windshield and you run the risk of serious bodily injury.
Old Sep 2, 2006 | 11:05 AM
Skiptomylue's Avatar
Then just dont get into a head on collision.. lol
Old Sep 2, 2006 | 11:12 PM
well goddamn it was an idea, use grade 10.9 bolts than i don;t know do it somehow. never done it.
Old Sep 2, 2006 | 11:47 PM
yiksing's Avatar
the giant tastetickles
A vented hood only works wonder if the car is moving sufficiently fast, removing the rubber where the hood and the windshield meets would be a good way to remove.
Old Sep 3, 2006 | 04:57 PM
Trekk's Avatar
Goat rider
The weird thing is, when you lift the hood like that the air is suppose to go in, not come out.
Positive pressure or something, NASCAR guys have been doing it for a longtime, you just dont see it on a NASCAR cause its cut down in under the hood. Not sure why car companies never add this.
Old Sep 7, 2006 | 07:38 PM
Jax_RX8's Avatar
Got Another Rotary
Not a good idea to remove the rear hood seal to let air out of the back of the hood.
If you are traveling at speed, there is inward pressure here from the hood/windshield angle and the air will push into the engine bay and out the bottom.
But, if you are going slow or not moving at all (not creating any pressure), heat and any engine vapors will escape from here and will and be be picked up by the interior air pickup located in that same spot - affecting the air coming into the cabin. That is why passenger cars never vent out the back of the hood - this is where the interior air pickup is and the pressure is used to feed air into the car instead of the engine.
NASCAR racecars take engine air from here rather than using it for interior feeding.
Stevent1986
Jun 3, 2023 08:56 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
thewatcher101
Sep 18, 2015 01:48 PM
