important int-x question
Old Aug 29, 2006 | 06:41 PM
joshk118's Avatar
where do i hook the freaking vacuum hose to? i looked on the video and it shows the spot, but there is already a rubber hose in that spot and i cant pull it out. is there another spot to hook it to?
Old Aug 29, 2006 | 09:05 PM
Moostafa29's Avatar
Storm Trooper
What is the other hose hooked up to?
Old Aug 29, 2006 | 09:49 PM
vdaf.
Old Aug 30, 2006 | 09:36 AM
KJ238's Avatar
Air + Fuel + Spark = Boom
Originally Posted by swoope
vdaf.
VFAD
Old Aug 30, 2006 | 09:40 AM
KJ238's Avatar
This diagram should help u... marked the point where u are supposed to connect with an orangey dot
Old Aug 30, 2006 | 10:11 AM
MazsportScott's Avatar
Mazsport.net
GENTLY twist and pull on the hose while pulling down. Do NOT splice a tee into this hose please. If you want to keep your vfad intact, splice a tee into the hose on the top of the manifold. The Interceptor-X hose should not have anythig else spliced into it. Scott
Old Aug 30, 2006 | 06:14 PM
joshk118's Avatar
k i got the vacuum hose connected, but now the int-x wont show power and my car will not start. i even took out the int-x and my car still wont start.. what is wrong with it?
Old Aug 31, 2006 | 09:05 AM
KJ238's Avatar
I've got 3 tees.... from vfad > int-x, boost controller, bov, defi boost guage sensor
would u recommend i take some of the other pressure sensor signals from elsewhere? If so which sensors, and from which port? There are 2 other ports... One on the left side and one behind the port where VFAD is
Old Aug 31, 2006 | 09:22 AM
epitrochoid's Avatar
Riot Controller
Originally Posted by stickmantijuana
i kinda miss talking to scott... that's why i'm currently trying to blow up my motor. jk. scott, please give me a call, 9pm, 10pm, 1am, or pretty much as late as you want.
yea, you get to talk to scott alot when you blow your motor lol
Old Aug 31, 2006 | 05:42 PM
evilmiata's Avatar
^^^Eh, you kind of DON'T get to talk to him. Just kidding. Mazsport has great support. I was up against the same wall doing my interceptor N/A install. The install video (available on his website) is very clear which hose to use, but just be sure that there isn't a 1-way check valve between the Interceptor and the manifold. The video shows an installation on the Greddy kit and assumes that the vacuum lines and check values have already been removed.
Check your battery, ground, etc. It should be pretty easy to trace back a bad electrical connection.
Old Sep 3, 2006 | 04:36 AM
yz007's Avatar
A turbo what?
joshk118 k i got the vacuum hose connected, but now the int-x wont show power and my car will not start. i even took out the int-x and my car still wont start.. what is wrong with it?
I bet it is your small ecu fuse in the fuse box under the hood on the driver side.
Good luck,
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
yankeepicker
Sep 11, 2015 05:42 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
