Wierd Amp/Subwoofer Problem
Old Aug 24, 2006 | 07:35 PM
Jeudew's Avatar
Hi everyone, my first post!
Here is my problem, I have a bose system in my car, I first tried to wire my Audio Control 6XS from the preamp wires. From there I went into a rockford fosgate amp, and finally into my JL Audio 10s.
When the RCA plugs are plugged into the amp 1/2 way so only the center pin is touching the bass works fine, but if I push the plug in all the way the bass cuts out.
From there I tried to get input from the rear speakers after the bose amp.
Now the bass is stronger with the RCAs plugged in 1/2 way, but if they are in all the way the subs just distort like I have bad noise in the wires, even with 0 volume.
Can someone help me with this wierd problem?
The only thing else I can think of is to cut the negative wire off of the RCA plugs going into the amp, although it makes no sense to me how it works with only the positive side.
Old Aug 24, 2006 | 08:38 PM
jstkilntim's Avatar
resU deretsigeR
Sounds like you have a wire crossed going to the 6XS, but I can't imagine you doing it twice if you tried before & after the amp. If you cut RCA plugs and soldered in, make sure the + & - isn't touching each other on either channel. Try another source (Ipod or something) before & after the 6XS and see if it changes. Could just be the amp. I know my cheap RF amp induces some noise.
Old Aug 24, 2006 | 09:09 PM
Jeudew's Avatar
Tried hooking an Ipod first directly through the amp, worked just fine.
Tried hooking the Ipod from the X-over to the amp, worked with alot more bass.
The subs only worked with the RCAs plugged in all the way.
None of the connections were touching each other in a bad way.
Do you think I have a faulty RCA wire somewhere?
Old Aug 24, 2006 | 09:37 PM
jstkilntim's Avatar
resU deretsigeR
Tried hooking the Ipod from the X-over to the amp, worked with alot more bass.I am assuming you mean through the 6XS.
Do you think I have a faulty RCA wire somewhere?Possibly, but it sounds like you have a + & - crossed where you tied them in.
Old Aug 24, 2006 | 09:54 PM
Jeudew's Avatar
They can't be crossed, I soldered the connections today and have only done the left channel off of the left rear 6x9. I haven't taped them up yet and can still see the connections. Positive to Purple and Negitive to Pink.
Posted by mdw33333
When tapping the rear speakers, use these colors:
Left Rear + is Purple
Left Rear - is Pink
Right Rear + is Black/Blue
Right Rear - is White/blue
Old Aug 24, 2006 | 10:49 PM
WikkedOne's Avatar
Deals on wheels
Posted by mdw33333
Left Rear - is Pink
In the sticky at the top of this forum it says this
# Bose radio:
* Door tweet left +R -W (door speaker connected direct to amp)
* Door tweet right +W/R -Y/R (door speaker connected direct to amp)
* Centre mid +L/B -G/Y
* Rear left +V -P (tweeters are co-axial, same colors)
* Rear right +W/L -B/L (tweeters are co-axial, same colors)
most importantly
Right Rear + white/blue
- Black/blue
which is backwards of what you have.. try to switch those and give it a shot
but then you say you have only done the left side... so I dunno..
Old Aug 25, 2006 | 04:42 PM
jstkilntim's Avatar
resU deretsigeR
Posted by mdw33333
Left Rear - is Pink
They are crossed!!
Black/Blue should be negative.
Black/White should be positive
Fix this and your problem should be solved.
Old Aug 25, 2006 | 04:47 PM
jstkilntim's Avatar
resU deretsigeR
Sorry Wikked, when I seen "they can't be crossed", I didn't even read your post.
Old Aug 25, 2006 | 05:07 PM
WikkedOne's Avatar
Deals on wheels
thats ok.. you also, like me, didn't read the part where he said he only did the left side... that ISN'T crossed...
Old Aug 25, 2006 | 05:12 PM
WikkedOne's Avatar
Deals on wheels
and speaking of "Wierd" problems..
isn't it weird that the word "weird" is an odd exception to the i before e rule... thats just for future reference jeudew
and I'm not trying to rag on you for bad english.. It was explained to me a long time ago... and I noticed that it is quite ironic, and I can't help bring it up when I see it.
Old Aug 25, 2006 | 10:25 PM
jstkilntim's Avatar
resU deretsigeR
At first I thought he meant that he only had one channel connected (that wouldn't have made sense w/ his scenario), but then I figured that he only had one soldered so far. I think.
Old Aug 25, 2006 | 10:32 PM
1145climber's Avatar
RX-8 Enthusiast
hahaha wikked.... a very good point. the word weird is... well... weird
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
