help!! broken rear wheel stud
Old Aug 20, 2006 | 03:57 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
i accidently over torqued the stock wheel lock and broke it. a small portion of the wheel lock was stuck and wouldnt come off. there was no way to take it off but to drill the wheel stud until theres no thread left. after that i have ordered a new wheel stud from www.onlinemazdaparts.com. and now i found out that theres not enough clearance to hit the broken stud out or install the new stud back on the rear hub. so if i remove the rear hub, would i need to replace the bearing? and if so, is installing the bearing hard or do i have to bring it to a shop? and will anyother things break?
thanks for any input!
Old Aug 20, 2006 | 07:46 AM
chrism's Avatar
Misfit Moderator TnC
i would suggest not doing this yourself because there are special factory tools needed for the hub, etc.....me, kel, bxb40 attempted this on kel's car and it was not working unless you took apart half the rear suspension or shaves half the head off the bolt to slip it in the assembley...good luck and take it to a dealer....it aint worth you messing more parts up......and be prepared to pay ludicrous amounts
Old Aug 20, 2006 | 09:56 AM
BoosTED's Avatar
cortc replaced his with titanium studs and said this about removing them:
You have to remove the front and rear spindles and support them around the lugs to remove the stock ones... You can press them out or hit them with a hammer carefully; you cannot hit them with a hammer or put impact pressure on the bearings as you will destroy the bearings and the bearing chase...
The fronts are easier than the rears as the fronts can be removed bearings and all with four bolts (Very cool...), the rears have to come apart...
https://www.rx8club.com/showthread.p...titanium+studs
There are a few pictures in there too.
Old Aug 20, 2006 | 01:37 PM
dsmdriver's Avatar
TeamRX8 says you can just bang them out of the back axle. Do a search...
Old Aug 20, 2006 | 04:59 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
you cannot just bang them out... the rear does not have enough clearance for me to bang it out. if it did....i wouldve done it long time ago.
Old Aug 20, 2006 | 05:07 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
does shaving off half the head of the bolt gives it enough clearance to slip it in without taking everything apart?
thanks
https://www.rx8club.com/showthread.p...=titanium+studs
thanks for the help and the link!
Old Aug 20, 2006 | 05:56 PM
supra0083's Avatar
I have replaced a stud on my 91 MR2 before and one trick I found useful to take the stud out is to use a C-Clamp in combination with a socket. Put the socket on the back of the stud and make sure the socket has a big enough hole for the stud to go in when you use the C-clamp on end of the socket and the end of the stud. You can then close the c-clamp to push the stud into the socket. Once the stud is loose, you should be able to take it out with your hand.
Edit:
Now I realize that the RX-8 disc is so much bigger than the MR-2's. This trick might not help at all. Also, not sure if there is a hole from behind that allow access to the stud.
Old Aug 20, 2006 | 06:07 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
wow thats a smart way to do it! but the thing is that i dont have enough clearance in the back to put the socket and the C-clamp. i think the only thing i can do is to take the hub off, then i can use your idea. and i am trying to find a way to replace the stud without taking the hub off. i just dont want the trouble to replace the bearing if i take the whole thing off... anyways thanks!!
Old Aug 20, 2006 | 06:28 PM
chrism's Avatar
thanks
it would help shaving the head but we didnt get that far...so i honestly cant tell you.....it was kels car so you may wanna pm him on his input....i was just there helping with the manual labor
Old Aug 21, 2006 | 08:24 AM
BoosTED's Avatar
The brake rotor comes off leaving the hub and studs.
Old Aug 21, 2006 | 08:54 AM
chrism's Avatar
yes but there is aluminum behind it and you cant get the studs out from a straight angle...you either need to drill/shave part of the head off the stud or do it the right way and dismantle the entire assembly....you will not get the stud out otherwise because of a bad angle
Old Aug 21, 2006 | 09:36 AM
dsmdriver's Avatar
Well, it was ULLLOSE, but he says it can come out. Thanks for just telling me I'm wrong instead of searching.
https://www.rx8club.com/showthread.p...ht=broken+stud
Old Aug 21, 2006 | 04:51 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
A little over a year ago I had to do a front and rear stud. The front was cake and I thought I did the rear just as easy, again long time ago not sure. I did look at the rear over the weekend and the only thing I can come up with is I pulled the rear caliper and fished it in there. You can look at my rear hub/suspension and see none of the bolts have had a wrench on them, everything looks brand new and no one else has ever worked on the car. Next time I have to replace one I will take some notes/pics. Wish I could say for sure how I did it. Guess it is magic just like my rear shock install
Old Aug 22, 2006 | 03:31 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
well thanks for everybody's help!! i really appreciate it! well now i have decided to take the whole hub off since i found someone with the tools to do it. i just hope that this will finally get rid of the head ache ive been having and make my baby look flawless again. haha
Old Aug 22, 2006 | 06:16 AM
chrism's Avatar
good luck......
WingleBeast
22
May 23, 2016 09:22 PM
Kahl
Aug 20, 2015 11:49 PM
Jazzmeson
Jul 31, 2015 01:48 AM
Jazzmeson
Jul 31, 2015 01:47 AM
Brandonien
Jul 30, 2015 12:33 PM
