re: competition tyre pressure
Old Aug 17, 2006 | 06:16 AM
deano's Avatar
Hi Guys,
I am using the OEM bridgestone tyres - can anyone suggest a good tyre pressure for doing Hill Climb or short Sprint work?
I am thinking 30psi all around - I have had a search on the forums but can't find any good information.
Thanks,
Deano.
Old Aug 17, 2006 | 06:30 AM
xxup's Avatar
Originally Posted by deano
Hi Guys,
Thanks,
Deano.
36 PSI COLD... That right Taka???
Old Aug 17, 2006 | 06:40 AM
deano's Avatar
Wouldn't the increased pressure give me less grip?
I am only doing 1.2km sprints with no tyre warm up.
Old Aug 17, 2006 | 08:19 AM
MACCAA's Avatar
At the Nats last year we found 36lb HOT was about right.This translates to around 30lb cold.
Cheers
Len
Old Aug 17, 2006 | 05:21 PM
Revolver's Avatar
Shootin' from the hip
And don't forget to have a quick check of the pressure immediately after each run (right Len?).
Old Aug 17, 2006 | 11:23 PM
takahashi's Avatar
Agree with MACCAA,
but with shorter climb you might want to have around 37or 38. I have 34psi hot with my slick at Winton!
Old Aug 17, 2006 | 11:49 PM
deano's Avatar
Originally Posted by takahashi
Agree with MACCAA,
Hi Taka - its hard to compare a slick to the oem bridgestone though.
I'm going to start at 30PSI - I will do one run at 36PSI as an experiment once I am up to speed - will post the results.
Old Aug 18, 2006 | 12:39 AM
takahashi's Avatar
I use to track my OEM bridgestone at Sandown.
Syd is a bit warm today and warmer in Qld?
36 hot is the lowest you go. The lower the pressure - the more heat you generate - so don't need that low pressure! I think 36 hot is good starting point - do you have a pump if you need more?
Old Aug 18, 2006 | 12:43 AM
deano's Avatar
Hi Taka - remember I am only doing 1.2km - thats the equilivant of what, 1/3rd of a lap at Sandown? - zero warm up, and full speed right from the start.
Do you still reckon start with 36 ?
I need maximum grip - the tyres will generate very little heat over that distance even at full speed.
Old Aug 18, 2006 | 12:48 AM
takahashi's Avatar
I suggest to have 34psi cold at least if not 36 cold to start with
Measure the tyre pressure after 1st run. I suspect it will go above 40psi. Drop it down to 38 psi HOT and try again. Drop further if you like after 2nd run.
Old Aug 28, 2006 | 05:52 AM
deano's Avatar
Hey guys,
I thought I'd post my results.
The quickest time was from 28psi all round. I would consider trying 26psi but am a little worried about the tyre rolling onto the side wall. At 28psi with the hardest cornering you could imagine - no marks on the side wall so tyre roll is hot a problem at that pressure with the OEM bridgestones.
I did a run at 36psi and another at 40psi - it was traction control city. Sure the car started to turn really easy - but I had zero grip.
28psi gave far better grip levels and resulted in a lot less work from the traction control system.
Everyone at the hill climb was very impressed by the RX8 launches - 6000rpm seemed to yeild the best results.
5 of us got to take some CAMS officials for a hot lap after the event which let me do a launch from 9000rpm on the rev limited. Smoked both tyres for about 200 metres - felt awesome and also a crowd pleaser.
Bring on the turbo!!
Deano.
Old Aug 28, 2006 | 06:51 PM
Revolver's Avatar
Woohoo! - not sure I'd be game to drop the clutch at 9K.
Glad to see you're having lotsa fun.
Old Aug 29, 2006 | 08:33 AM
deano's Avatar
I kind of slip it for a second then let it out - its all good.
Old Aug 29, 2006 | 09:02 AM
timbo's Avatar
rock-->o<--hard place
Hmmm....is that the stock clutch?
Old Aug 29, 2006 | 10:13 AM
deano's Avatar
Yes - no slippage at all.
Old Aug 29, 2006 | 07:02 PM
Revolver's Avatar
...yet!
Old Aug 29, 2006 | 07:19 PM
deano's Avatar
...yet!
oh well - better the clutch than the gearbox :-)
Old Aug 29, 2006 | 07:22 PM
Revolver's Avatar
Correct!
cliffkemp
Dec 24, 2024 10:48 AM
Azki23
Jun 27, 2018 03:48 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
