Question about bird shit
Old Aug 14, 2006 | 07:57 AM
Ol1i3x's Avatar
Question about bird ****
Unfortuntely i left my car uncleaned for too long and now after i washed it, the bird **** on the back has left a faded white smudge... is there any product i can use to remove this? (i tried soap and scrub but its burned in pretty strong)
Old Aug 14, 2006 | 08:02 AM
sorry but, like you said, u left it there for too long. and theres a burn in mark now.
What you can do is, wash your car MORE often now and the sun will take care of the rest.
Old Aug 14, 2006 | 08:08 AM
NoTears316's Avatar
Shock and Awe
Try the liquid wax from Johnson brand with a soft cotton cloth, it should be able to remove the stains... or a polisher.
Old Aug 14, 2006 | 08:21 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
Carry quick detailer and microfiber cloths and vow to never again let bird **** stay on your baby any longer than 2 or 3 minutes after you see it.
You can polish it out if you're lucky, but it'll cost you part of your clearcoat. I'll let others on the forum tell you how and with what.
Old Aug 14, 2006 | 01:18 PM
BlueSky's Avatar
I heard from a friend not long ago that bird **** if left on your car can and will permanently damage your paint. So you're prolly SOL.
Old Aug 14, 2006 | 01:31 PM
lshu's Avatar
Driving makes me :)
Be sure to clean bird **** that lands on any rubber trim IMMEDIATELY. I mean ASAP!! I went to the beach one day, played volleyball for a few hours then came back to my car just to see a huge **** on the driver window/rubber trim. I had quick detail in the car and wiped it off as fast as I could, but it was already too late. The rubber had been eroded away leaving a indentation in the shape of the vitriolic bird poo.
To remove the stain, try using a stratch remover such as Meguiar's Scratch-X or a heavier duty rubbing compound for tough stains. Employ preventative maintainence and always have a good coat of wax on your paint at all times.
Old Aug 14, 2006 | 01:44 PM
buyinan8's Avatar
Muff Driver
Depending on how deep the stain is into your clearcoat, you may be able to polish it out. Try Meguiar's fine cut cleaner.
Old Aug 14, 2006 | 09:26 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
Try a little ammonia, the detergent type - cut with water and use a soft electric toothbrush, (this will help lift oily proteins) and this should make a white foam, rinse and if it's still there, follow with water and baking soda (this helps neutralize bird stomach acid) - rinse, if its still there then follow with sugar on a lemon ( this is a mild abrasive and an acid which will react with any remaining baking soda, and again help remove oils and proteins) - don't press down too hard and you might be able to lift it without scratching -
Good luck, tell us what worked.
Old Aug 15, 2006 | 12:51 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Bird poo sucks! Damn birds.
Old Aug 15, 2006 | 06:14 PM
corners's Avatar
An RX ate my baby
Keeping a good coat of wax on the car helps keep future bird stains from happening, too.
Austin22
Sep 23, 2015 04:46 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
