Anyone have trouble finding Reverse?
Old Aug 12, 2006 | 07:07 PM
mshea's Avatar
Seriously - I know where it is 'supposed' to be in my '05 MT car. Occassionally, the bugger just won't shift into reverse! One would think Mazda could make this a more distinctive 'click click'.
Anyone else having this issue/solution?
Old Aug 12, 2006 | 07:10 PM
dupa12345's Avatar
not at all .. quite amazed with it actually .. every time i think i just put it in 6th it is in r
Old Aug 12, 2006 | 08:03 PM
LionZoo's Avatar
road warrior
Did you push down on the shift ****? I haven't missed reverse yet (knock on wood).
Old Aug 12, 2006 | 08:06 PM
mysql101's Avatar
I sometimes think it's locked into reverse and it's only half way in, so soon as I give it gas, I hear a buzzing sound as the engine spins it.
Old Aug 12, 2006 | 09:33 PM
Brettus's Avatar
Boosted Kiwi
me too on that one - there are occasions when the gears don't mesh & I have to take it out of gear , let off the clutch then back in with the clutch & try again.
Old Aug 13, 2006 | 07:19 AM
RX8Maine's Avatar
+1 That's happened to me a couple times, usually when I am not paying as much attention.
Old Aug 13, 2006 | 07:14 PM
mshea's Avatar
Honest - I know how to drive. But there are times when reverse is just impossible to lock into. There is no reaction to the depression of the shift ***, no click-click and only 6th gear to be found. It seems to hapen most often when the car is hot. Odd.
Old Aug 13, 2006 | 07:22 PM
NgoRX8's Avatar
get a short shifter. you will feel it "click-click"
Old Aug 13, 2006 | 09:44 PM
ZoomZoomH's Avatar
Mulligan User
put it in first then into reverse.
Old Aug 13, 2006 | 09:48 PM
Labop's Avatar
ditto. plus it takes a few tries to get it to go in. Very occasionally it is so bad that I have to put it into 1st and roll forward a bit. That seems to do the trick and it slips into reverse easily.
Old Aug 13, 2006 | 10:46 PM
Jackallll's Avatar
same here....gotta engage first sometimes which is not helpful when there's a wall/car in front of you. i never grind the gears anymore as i can tell when it's engaged or not. it's just one of those quirks we have to deal with.
Old Aug 17, 2006 | 09:56 PM
mshea's Avatar
OK, thanks for the tip. First 1st, then Reverse. I can remember that one. Glad I'm not the only one having this curious problem.
BTW - the 'Sqealing Brake ' TSB was performed this week and the car is now quiet and brakes like a champ. I couldn't be happier.
Old Aug 17, 2006 | 10:01 PM
Im_DANomite's Avatar
I love GOOOLD
reverse doesn't have a synchro...it's a dogged toothed gear (hence the loud noise when driving in reverse). dogged tooth gears are stronger but noisy. get in the habit of sticking it 3rd (or any other gear) and THEN into reverse.
first gear can also act the same, although different reasons. if that happens, shift into 2nd and then first...get into the habit.
all cars do this.
theblinkof
Oct 4, 2023 05:24 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 27, 2015 07:49 AM
Evan Gray
Sep 26, 2015 12:30 PM
