LPG conversion
Old Aug 9, 2006 | 09:31 PM
fatmarco's Avatar
LPG conversion
With all the talk of LPG in the media right now.
Does anyone know if it is possible for rotaries?
I don't know anything about lpg and am not interested in this for economy just curiosity.
Perhaps it could be directly injected into the chamber in liquid form?
That would give good cooling effects.
anyone know?
fatmarco
Old Aug 9, 2006 | 09:34 PM
Revolver's Avatar
Shootin' from the hip
Not sure but the first thing I think of for the 8 is where in hell are you gonna fit the tank?
Old Aug 10, 2006 | 04:03 AM
xxup's Avatar
Roof racks????
Old Aug 10, 2006 | 06:26 PM
Revolver's Avatar
Originally Posted by xxup
Roof racks????
The first Red Bull RX8 sponsor car?
Old Aug 10, 2006 | 08:12 PM
rotarenvy's Avatar
I think there are a few LPG rotary's. try ausrotary.com
Old Aug 11, 2006 | 08:56 PM
auzoom's Avatar
Hmmmmmm.........
Yes you can convert a rotary to LPG, but I dont know if anyone has done it with a renesis. Rotaryenvy is correct that you can have a squiz at ausrotary for info on pre Renesis rotaries converted to LPG but I dont believe you will find anything about a renesis. My suggestion is go and have a chat to your local LPG convertor.
Old Aug 12, 2006 | 07:09 AM
Kas's Avatar
Kas
- Senior Menber -
whats the diff with a renesis to any other injected rotary?? none
with a rotary however you would need full gas research...
Old Aug 12, 2006 | 07:24 PM
auzoom's Avatar
Hmmmmmm.........
Ask the guys trying to turbo and supercharge. You cant just change over to LPG, change plugs, adjust timing a bit, etc. The ECU has a large say in just about everything the car does and I cant imagine it would just accept a change to LPG.
Happy for you to be the test mule.
Andrew
Old Aug 14, 2006 | 06:59 AM
glenn's Avatar
Andrew
Most LPG conversions use a simple mixer setup to introduce the gas. This sits in front of the throttle body and they then cut the signal to the injectors. I dont see why this wouldnt work ok on a renesis. As long as the LPG mixtures are ok the cars ECU wouldnt know the difference.
I have done several LPG conversions to earlier rotarys and they work well. I once built an 86 mazda 929 with a 13b turbo cosmo motor on gas and I used to tow my caravan with it
The big problem with the RX-8 will be fitting the tank.
Old Aug 14, 2006 | 07:01 PM
Grizzly8's Avatar
Glenn
Can the existing petrol tank be modified to take the gas?? why is there a need to fit another tank .
michael
Old Aug 14, 2006 | 07:30 PM
auzoom's Avatar
Hmmmmmm.........
I hear what you are saying and I reckon it would be great to be able to run the 8 as dual fuel, especially if you could have "Removable" LPG tank. But as with most things with the 8 I doont think it will be as simple as with previous rotaries.
Originally Posted by Grizzly8
Glenn
michael
Michael, a normal petrol tank is not designed to hold the preassures required of an LPG tank. consider your BBQ gas tank and the "solidness" of that. petrol tanks are a far cry from that. However this is not to say that if you wantto run purely LPG that you couldnt replace the existing tank with and LPG one.
Cheers
Andrew
Old Aug 14, 2006 | 07:35 PM
Revolver's Avatar
Maybe my memory is playing tricks on me but isn't our fuel tank a saddlebag type arrangement? I also seem to remember reading somewhere that it's not even steel, let alone of the kind of thickness to accommodate the pressure of LPG.
Old Aug 14, 2006 | 10:43 PM
Grizzly8's Avatar
Dave you are 100% correct but it would give us one hell of a Bang
Michael
Old Aug 14, 2006 | 10:54 PM
auzoom's Avatar
Hmmmmmm.........
LOL, and I am sure there are a few that would want that bang treated as a warranty issue :-/ Joking
Old Aug 15, 2006 | 04:24 AM
xxup's Avatar
And let's not forget that this monster tank is not going to do anything good for the 50/50 weight distribution of the 8..
Old Aug 15, 2006 | 04:31 AM
mikeyr's Avatar
i need a new photo
Bugger that, stick it on the passnger seat, bung a wig and a hat on it and those T2; blues just fade away!!
Old Aug 15, 2006 | 08:42 AM
xsfer's Avatar
what a f$ckin stupid thread, what moron would honestly even consider converting a rx8 to lpg....
c'mon, get your head out of the clouds...
Old Aug 15, 2006 | 08:46 AM
dbrx8's Avatar
bezoomy
RIGHT ON !
Old Aug 15, 2006 | 06:35 PM
Revolver's Avatar
Read his first post again ******** - he's posing a hypothetical.
Nobody's forcing you to read it. Not interested? Then **** off somewhere else.
As for Mikey's idea - everybody would think you've got a really fat, ugly girlfriend!
Old Aug 15, 2006 | 07:05 PM
xsfer's Avatar
revolver, if its hypothetical, why don't you try the theory of sticking a shovel up your ****!
lets try converting the rx8 to jet fuel, maybe entirely ethanol? fill the boot up with batteries and make it a hybrid...
stop being a post ***** and get a life....
Old Aug 15, 2006 | 07:18 PM
Revolver's Avatar
Thanks for the free advice but my life is just grand thanks.
Though judging by the venom spitting from your two posts today, it sounds like yours could do with some improving. Cheer up.
Old Aug 15, 2006 | 09:13 PM
auzoom's Avatar
Hmmmmmm.........
Post ***** that he is , he had a valid point:
Occasionally people just like to hear what other have to say no need to get nasty
Old Aug 15, 2006 | 09:22 PM
fatmarco's Avatar
Yes it is a hypothetical.
But as i was reading over at ausrotary thanks to the tips here, someone is trying it with an older rotary engine.
You may think it is a stupid idea, but only because you are are limited yourself.
If hypothetically, direct liquid injection makes the engine more powerful and more efficient, it would certainly be interesting. Not only to rotary owners today but for the future development of the rotary engine.
And there is every indication to suggest that rotaries are well suited to lpg.
Old Aug 15, 2006 | 10:28 PM
Revolver's Avatar
Ah, Andrew. You know me so well.
Actually, I think I prefer 'post ****', 'cause from what I can gather, ****** get paid.
Yes, yes. I know. 'Legal *****' fits.
Back on topic - keep us posted Fat Marco - I'm interested to see how the project being discussed on AusRotary goes.
Old Aug 27, 2006 | 06:16 AM
Cromax's Avatar
Buzz Buzz Buzz
Look ... back on track guys ...
... I'm sure most of you will recall that Mazda have road tested a dual-fuel setup on an RX8 using Hydrogen instead of LPG. I'm sure it is completely possible, and our 50/50 weight distribution won't be affected all that much (I reckon it's a bit of a **** job anyway).
You could most likely get someone to replace your petrol tank with a custom LPG/CNPG tank so it reduces wear on suspension components.
