What does this mean?
Old Jul 29, 2006 | 02:17 AM
kunz's Avatar
•▫▪› is way, way way way way way way way way wayyy better than you ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ▪ ;)
While driving today, my oil light, brake light, traction and ABS light came on. As this happened, the ECU limited my speed from ~110 to 100.
They remained lit until I got home and restarted the engine. Any ideas on what exactly happened and why they came on?
sCANalyzer does not report any DTC error codes either. oil + all fluid levels seem to be fine.
Old Jul 29, 2006 | 02:50 AM
kunz's Avatar
Originally Posted by xxup
Got plenty of oil in the engine and air in the tyres.??
Yup, oil is almost at the full mark and just checked the tire pressure and its avg around 32 psi (I pump it to around 35 each time and i last filled it with air 2 weeks ago)
EDIT: Where'd xxup's comments go? lol
Old Jul 29, 2006 | 02:57 AM
have read about a couple of steering wiring harnes problems that have caused this symptom...
Old Jul 29, 2006 | 03:07 AM
xxup's Avatar
Ah well... I had another look at your post and realised that you had checked the oil levels.. Reinforces my old teacher's comments "bright kid who can solve very complex problems, but sometimes lacks attention to detail"
Old Jul 29, 2006 | 06:42 AM
sco's Avatar
sco
Smells like a wiring fault to me. Loose connector to the PCM??
Old Jul 29, 2006 | 06:44 AM
kunz's Avatar
Hi Ross =)
Thank for that, i'll check up on it tomorrow.
Any other suggestions?
Old Jul 29, 2006 | 01:29 PM
Gomez's Avatar
Shifty Bastard.
Battery terminals/battery condition.
Old Jul 29, 2006 | 06:38 PM
mikeyr's Avatar
i need a new photo
More dodgy wiring, that's two on a sunday morning weird!
Old Jul 30, 2006 | 07:08 AM
kunz's Avatar
hmmm while driving today on the highway again, the DSC light switched on and switched off 5 seconds later.
taking it to mazda tomorrow :\ what the hell is going on? lol
Old Jul 30, 2006 | 07:23 AM
takahashi's Avatar
Maybe the car hates you ? I
Old Jul 30, 2006 | 07:29 AM
kunz's Avatar
aaahah i dont think so :P its just 'sick'
Old Aug 5, 2006 | 10:01 AM
kunz's Avatar
Good news pple, it was cos of a loose/dirty traction sensor.
Old Aug 5, 2006 | 10:15 AM
Gomez's Avatar
Shifty Bastard.
ABS sensor?
Old Aug 5, 2006 | 10:37 AM
kunz's Avatar
Yup. The car kept doing that every day until Thurs, even with speeds of around 70'ish and taking corners it felt as though the DSC was off.
Had the car booked in on Thursday - delivered to Westend at 8am. They plugged it into their computers and it showed a DTC "Mismatch" error code. (I'm still wondering why sCANalyzer didnt pick that one up hmm). Anyway, they went over everything, to check if it was all plugged in properly then took it for a test drive with their diagnostics computer and couple and could not find the problem.
I got called at 10am to come down and take the tech out as he could not duplicate the fault. Anyway, went down to the M4/great western hwy with him for around 20 minutes, and it didnt do anything. The car drove normally, took corners the way it does when DSC is turned on so I left it at that. They said it was most probalby a loose connection/dirty sensor cos thats all they actually checked before taking it for a test drive.
Its (almost) Sunday now and it hasnt played up since so i guess that was probably it.
Old Aug 5, 2006 | 04:08 PM
xxup's Avatar
These are the sensors near the wheel????
Old Aug 5, 2006 | 10:56 PM
mikeyr's Avatar
i need a new photo
My bloody DSC light just came on as well.
Hit a pothole the size of Texas yesterday...hoping it's not related!!!!
Old Aug 5, 2006 | 11:59 PM
kunz's Avatar
I guess so. I think there is a sensor at all wheel hubs which are directly connected to the PCM and report wheel speed and trip when one wheel spins faster/slower than the rest (wheel spin). I'm not 100% sure if thats how it works, but thats what I got told anyway.
mikeyr - the DSC lights (if only DSC) comes on when there is abnormal wheel speeds thus wheel spins. If you hit a pothole, then its pretty normal for the DSC to probably come on as there will be some minor difference in wheel speeds depending on which wheel goes over the bump etc.
If it comes on again during normal driving, then you might need to get it checked out.
Old Aug 6, 2006 | 03:10 AM
mikeyr's Avatar
i need a new photo
Feel in the holes yesterday, no drama then, came on this morning, so off to the dealer i guess!
Old Aug 6, 2006 | 03:17 AM
kunz's Avatar
Argh! Hope things get sorted out before the cruise!
Old Aug 6, 2006 | 07:39 PM
Revolver's Avatar
Shootin' from the hip
Keep us posted Mike.
We might be discovering another problem that needs to be checked out while warranty is still good.
