Cruise Control
Old Jul 28, 2006 | 07:40 PM
vertalop's Avatar
Cruise Control
My PI Japan Spec 8 cruise control will not work above 102Kph. Is this normal and if so how do I increase this limit? If I can't set at least 110 on Malaysian highways (preferably more) it is useless!
Old Jul 29, 2006 | 10:42 PM
sgrenesis's Avatar
THE GREAT WHITE
best to check with dru8999
Old Jul 30, 2006 | 10:33 AM
lennon's Avatar
I try it on 105km before....... It's good that it's limited for safety reason....... It's easy get into trouble, becos your reaction time will be slower than before..... You dont want some unconsiderable bloke to cut in front of you......
Old Jul 30, 2006 | 09:37 PM
dru8999's Avatar
Will try it out once I have the chance as I don't use the car much.
Old Jul 31, 2006 | 06:24 AM
theboy's Avatar
RX8 newbie!
yes its set not over 100+ cause it was tested that u can't stop quick enough incase of accident.
Old Jul 31, 2006 | 08:57 AM
sgrenesis's Avatar
THE GREAT WHITE
Is yours an auto.
Old Jul 31, 2006 | 09:26 AM
lennon's Avatar
Is yours an auto.
It's exactly opposite......
Old Aug 1, 2006 | 08:27 PM
vertalop's Avatar
Cruise Control - Safer at Any Speed
If someone cuts in front of you you put on the brakes, with or without the cruise control on, it makes no difference. If the cruise contol is on it is automatically disengaged as soon as you touch the brakes.
The big advantage of using cruise control is that you do not have to keep looking inside the car to check your speed every few seconds. You keep your eye on the road all the time knowing the car is taking care of the speed control a lot more accurately than you can do it. If you are doing 120Kph and it takes (say) 2 seconds to look inside, adjust your eyes, check the speed, look outside and wait for your eyes to adjust again, you will have travelled 66 metres while not looking where you are going! And you probably do that several times every minute. Dangerous lah! Safer to be looking outside and noticing hazards all the time.
Also cruise control saves fuel as it keeps a constant speed with very small throttle adjustments. Not like when we drive...look inside "oh 5Kph slow!" big boot on the gas pedal. Later...look inside "oh 5Kph fast" big boot off the pedal. This wastes fuel.
Limiting the authority of the cruise control to 100Kph does not make sense.
Old Aug 2, 2006 | 10:02 AM
c h o x's Avatar
Stock...
Hi all,
Allow me to share my experience in driving cruise controlled cars. I own 2 cars previously when I was overseas, both cruise controlled. One 4AT and the other 5MT.
I agree with vertalop on reaction time...cruise control on or off does not impose additional time for braking, unless of course you drive like me, both legs on the seat when travelling long distance. In any case, you're suppose to keep a safe distance from the vehicle in front, so that when he slows down, you'll not be force to disengage your cruise control.
Driving with cruise control on does in fact saves gas, on the condition the roads have to be flat in general. For the 5MT, the control supply more fuel to the engine in order to cope with the decreasing speed when driving up slope. As for the AT version, if the car senses a up slope steep enough, it'll automatically down-shift to maintain the current speed...this waste gas and over a long distance, you might end up using more gas...
Oh, one last thing...I've never heard of cruise control disengaging at 100kph. I've use mine up to 180kph without any problem.
Old Aug 5, 2006 | 03:53 PM
HKS17's Avatar
Mine is 6spd MT from MM, any cruise control?
Old Aug 6, 2006 | 12:44 AM
sqflyer's Avatar
Heavy Machinery Operator
MM spec 8s do not have cruise control. If it did, you would definitely see the "controls" because that's what you need to use in order to control the cruise control. If you can't see any cruise control "controls", then you don't have cruise control.
Old Aug 6, 2006 | 06:17 AM
lennon's Avatar
Andrew, i never check the KPH while i'm driving, unless i'm checking if i ever hit 250KPH....... So i dont use the cruise control...... the first time i use it is also the last time....... Almost three years ago.....
The speed lmiter on your cruise control might have something to do with japan specs.......
pjwermuth
Sep 28, 2015 11:36 PM
Wurromurro
Sep 20, 2015 05:02 PM
titaneum_grey
Sep 6, 2015 10:21 PM
