Which cat wont burn up after leaning the car?
Old Jul 28, 2006 | 12:18 PM
unreal89's Avatar
I don't mind pistons
Question Which cat wont burn up after leaning the car?
Hi guys, I'm planning to build a custom 3" single exit header-back exhaust. My question is... Which universal cat converter will NOT burn out after tuning the car for better AFR's?
I was thinking that the MetalCat that SC-ed is using will do well, but its like $130 and some people like RotaryGod and TeamRX8 have been saying a cat is a "get what you pay for" kind of thing.
I don't want to spend $400+ dollars on a cat, I'd rather go catless. So does anyone know for sure, or pretty close to sure, what cat in the sub $200 range can withstand the exhaust temperature of a leaned-out Rx8?
Also, Can I mount the cat further back so it is exposed to less heat. The exhaust will cooll a little bit maybe. I'm not good on this subject, so please shed some light.
Thanks a lot!
Old Jul 28, 2006 | 12:22 PM
rotarygod's Avatar
A hollowed out one!
I burned out a Catco cat on an RX-7 in about 6 months of normal driving. I have a Bonez cat that I've swapped back and forth for a while now but I only drive the RX-7 less than a thousand miles a year. In the past I used the Bonez cat for probably 2 years as a daily driver in the past though and no issues. I've flooded the engine several times through it, run it rich, run it lean and haven't had any issues with it. Saying that it will probably clog the next time I start it up. I bought it through Rotary Performance.
Old Jul 28, 2006 | 12:24 PM
rotarygod's Avatar
To elaborate a little more, if you lean it out enough no cat will survive for long. Some will just do better than others. Your best bet would be to run catless and then reinstall it one day a year for inspection. That's what I do.
Old Jul 28, 2006 | 12:32 PM
unreal89's Avatar
Will moving the cat further back help at all?
Old Jul 28, 2006 | 02:15 PM
rotarygod's Avatar
It will keep the cat cooler but will also make it less effient at cleaning the air. It needs to be hot. Legally you can not move it back and many people are concerned with legality reasons. You wouldn't pass a visual inspection with it moved back.
Old Jul 28, 2006 | 02:46 PM
unreal89's Avatar
catless it is
Old Jul 28, 2006 | 03:12 PM
dgrx8's Avatar
FN GR8
Talking unreal...
please post some pics when you get this all done...
Old Jul 28, 2006 | 04:12 PM
unreal89's Avatar
I'll borrow my aunt's digi cam during the install... My bro's is borrowing my money right now, so I can't do it right now.
Old Jul 28, 2006 | 11:49 PM
there are cats out there rated for 2100 degF
Old Jul 29, 2006 | 09:34 AM
really, where?
Old Aug 22, 2006 | 10:24 AM
silverwolf's Avatar
damn it im gettin a midpipe and just installing the cat housing around the midpipe so i can pass any visual inspection btu once i turn on my car i can roast the cops car as i drive off with no ticket.
Old Aug 22, 2006 | 01:16 PM
rotarygod's Avatar
Be careful. You'll make the environmentalists here mad! FWIW, I have done the same thing on all of my RX7's.
Old Aug 22, 2006 | 02:17 PM
silverwolf's Avatar
haha
rotarygod i knew i liked you!!! awsome. well done. my neighbor has a gen 2 rx7 with a turbo'd buick engine. and i love them. ps how many rx7s have you had / currently have?
Old Aug 22, 2006 | 06:55 PM
gh0st's Avatar
i know random technologies makes decent cats. model # 141-30000 is a 3 inch round matalic round cat that flows 598cfm. its over $200 though.
im too cheap for that so im gonna get a magnaflow/carsound instead for like 70$ off ebay.
Old Aug 23, 2006 | 02:12 PM
gh0st's Avatar
well.. after looking into the magnaflow/carsound stuff, i found that model number 53009 although high flowing was only good for about 1000' f. to be safe, i got the 59929 which is matalic and is good for up to 1800-2000'f. it was tested by ls1 guys to flow about 598-600 cfm and it only costs $20 more.
tbiggybig
Aug 13, 2016 06:30 PM
dbarber
Jul 25, 2015 01:34 PM
Jvswan
28
Jul 23, 2015 09:02 AM
yapakanichi
Jul 20, 2015 02:17 PM
AussieGray
Jul 16, 2015 03:58 AM
