Just ran my car at Raceway Park, NJ
Old Jul 26, 2006 | 10:25 PM
Bart!'s Avatar
RAWR!@#
First run.. 14.3, second run 14.65, third run a 14.02 with a boost leak :]
95f, w/ humidity and regular tires.
Wish I had a scanner!
Old Jul 26, 2006 | 10:28 PM
Moostafa29's Avatar
Storm Trooper
Don't think you'd help sell the turbo with those numbers? J/K.
Did you ever run NA?
Old Jul 26, 2006 | 10:32 PM
dillsrotary's Avatar
jersey fresh
not bad, with better tires and some practice launchin that sucker you'll hit mid 13's probably
Old Jul 26, 2006 | 11:15 PM
RotaryRider36's Avatar
Nice job bart. Like everyone else said, some better tires will work wonders. You get the MS kit put on yet?
Old Jul 27, 2006 | 12:01 AM
Skiptomylue's Avatar
not bad!, but i bet it would be A LOT lower if you didnt run in 95F... go around the end of the summer, when its only 15C/60F. With almost no humidity, i bet that time will drop just on weather alone..
Old Jul 27, 2006 | 12:49 AM
Bart!'s Avatar
RAWR!@#
Thanks thanks and thanks. I'm still getting quotes from body shops, the kit is ready to get painted. Selling the car after that, or trading it for my friends EVO8. Regardless, I'm picking up a totalled 93 FD within the next couple of weeks.
Mike: can you ask Paul the number and location of that body shop he was talking about, the one that you guys do all your work at..
Old Jul 27, 2006 | 07:21 AM
rkostolni's Avatar
Didn't you just install that turbo kit like a month ago? Why are you selling it already?
Old Jul 27, 2006 | 10:23 AM
Bart!'s Avatar
RAWR!@#
Because I want something faster.
Old Jul 27, 2006 | 11:26 AM
dmp's Avatar
dmp
RX8 and a Truk....
TRAP speeds my good man - what were your trap speeds?
Old Jul 27, 2006 | 02:50 PM
MazsportScott's Avatar
Mazsport.net
So how fast do you want to go?
Old Jul 27, 2006 | 03:31 PM
rob3379's Avatar
Well why don't you enlighten us on your mad creations Scott.
Old Jul 27, 2006 | 10:04 PM
rotorocks's Avatar
RotoRocks Powered
You need faster?
Just on the 65HP ZEX Nitrous Kit with no tune, RX8 makes better times than any of the Evos out there. I never did track, but but blowing away any street car is no problem at all.
Dont sell the 8, put on good tires and tune it and shell reward you beyond imaginable.
Old Jul 27, 2006 | 10:25 PM
rkostolni's Avatar
From my drag simulator, running 10psi you should be able to do a 13.4 sec 1/4 mile.
For anyone who's interested this is a pretty cool tool. Much more accurate than the usual online calculators. You need a dyno graph of your car to really make use of it though. I've compared it to some emprical data and its usually pretty accurate.
http://www.tucows.com/preview/279382
Old Jul 27, 2006 | 11:41 PM
dmp's Avatar
dmp
RX8 and a Truk....
Originally Posted by rotorocks
You need faster?
You quoted the wrong guy
And I'd bet $$ a stock EVO would MURDER a +65HP N2O rx8. Wouldn't be close.
Old Jul 28, 2006 | 02:03 AM
what type of evo is he talking about though?FQ-260?FQ-300, FQ-320 or the FQ-400.. ?
either way, the higher output MR FQ'a Need to be serviced a lot, and need to be takin care of.. they break down pretty easly, and require maitance more often the most highpowerd cars.
Old Jul 28, 2006 | 11:53 PM
Kel Rx8's Avatar
if your not 1st your last
tires are very important.
Old Jul 29, 2006 | 08:59 PM
adrian-1's Avatar
Ex- member.
Ditto on the tires and the temp/humidity.
I'm also interested in what your trap speeds were.
Your setup is pretty identical to what I had before removing everything and selling it.
My best was 13.1 at 107mph. Post is here. This site has my previous times.
13.1 with 275 drag radials and no psg/rear seats, 13.6 with some 255 falken rt615's and full interior, 13.9 with 19's and a boost leak.
Old Jul 29, 2006 | 09:19 PM
jersey fresh
didn't you engage a higher boost once shifting into 2nd gear?
Old Jul 29, 2006 | 09:39 PM
adrian-1's Avatar
Ex- member.
Yes. It was 8psi in first gear and then 11psi for 2nd gear and on. Although, the psi drops back down to 8psi in HIGH rpms so I really wasn't at 11psi until 4th gear. I recorded my boost gauge readings for that run in the video post.
Now on the street.... flooring it at 3k rpms at 11psi was lots of fun. (it'd drop down to 8psi around 6.5krpms.) I went up to 12psi and anymore would require bigger injectors.
MarkX
Jul 31, 2015 07:50 AM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
mazdaverx7
Jul 21, 2015 07:31 PM
