Tach Sweep on Starting - Flash indication?
Old Jul 18, 2006 | 07:40 PM
TRZ750's Avatar
Had the starter motor bulletin change done the other day (just for the heck - no real starting problem and got new plugs after 24K miles). Since then with a COLD start the tach swings full up - down to zero - then to correct reading. This only occurs when fully cold. It does not occur when the summer heat has warmed the car, even after sitting overnight in the garage if I sleep in. Feel this must be a flash indicator, but funny since it would not do it for a tech when the engine is warm. No other problem.
Is this a flash indication.
By the way Jim Ellis in Atlanta is a great dealer. They have done everything I wanted and all bulletins for free.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
Kim Jong Illest
Aug 6, 2015 02:34 PM
dbarber
Jul 25, 2015 01:34 PM
