Strange noise and power loss
Old Jul 15, 2006 | 10:37 PM
RX8Crew's Avatar
When throttle is depressed quickly, engine makes a quick "sucking sound", as if there was an air leak somewhere near the intake manifold. Car is also down on power. I have checked all of the vacuum lines and check the tightness of the manifold bolts, and everything looks OK.
Any ideas?
Old Jul 16, 2006 | 12:01 AM
so you just got you 8 and you have problems... and some how you found this site......
o wait and you got into the right section of this site.....
you must have searched to get this far.... why did you stop.
ok... i will play the game... what is your build date.... where are you located, auto or manual????
i have lots of ideas.....
btw, killer first post..
search billyd20 has like problems
Old Jul 16, 2006 | 12:07 AM
theboy's Avatar
RX8 newbie!
Any ideas?
Your filter is dirty? time to change? or is there any leak at your exaust.
Old Jul 16, 2006 | 07:51 AM
RX8Crew's Avatar
Actually it's my son's car. He races it in the SCCA IT class. It's a manual gearbox, but I don't know the build date. He had removed and replaced the air intake prior to this problem. At my suggestion, he did remove the intake again and made sure all the o-rings were seated properly. The engine also has a slight backfire under quick deceleration.
Old Jul 16, 2006 | 07:02 PM
It's obiuosly sucking in air, recheck the install.
Did he remove the VFAD?
Backfire is normal.
Old Jul 17, 2006 | 12:23 AM
Backfire is normal.
as razzi said also check the maf o ring..
Old Feb 22, 2007 | 07:47 AM
turbine's Avatar
4th Year runnin
I unplugged the VFAD, but left the hardware in. Do you think that may be a problem? When the car acts up, which is around 45 min or interstate drive, it pings everywhere. Strange marble sounds coming from the intake. Sometimes I can hear clicking around the spark plugs. All connections are good. New coils, plugs, wires, and wire seperators. New air filter and clean MAF. All fluids are changed before time. I take good care of this car, but I do drive it hard. I was leaning toward the heater core, because it changes a little when I use the heater. The sounds are coming from the intake more than the glovebox, and I am getting a major power loss. From what I have read the heater core does not have perfomance issues.
I have been on the fence to purchase the Inter-X for a year. I did not want to buy it and problem still exists. I am wondering if that may be the answer to it all. I do have the typhoon intake. I know it could not be the contributor for this much problem, but it could be. So I have considered getting the RB intake first. I just don't want to dance around the problem anymore. Help!
Old Feb 22, 2007 | 07:48 AM
turbine's Avatar
4th Year runnin
Question
How does the ring affect it?
Old Feb 22, 2007 | 09:09 AM
Mazda-Rati's Avatar
the WANKEL made me do it
^A tear can occur on the rubber of the MAF O-ring when removing/re-installing it allowing unmetered air to enter the engine.
The sucking sound when depressing the pedal quickly at idle is normal. The 8 has an electronic throttle body there is a slight lag time between the pedal and the throttle. If that concerns you, you should do this on a 6s. You press the pedal quickly at idle and there is a looong time that goes by before you hear the sucking sound of the throttle plate opening.
down on power? check your plugs and coils
Old Feb 22, 2007 | 09:21 AM
turbine's Avatar
4th Year runnin
Air will get by even if the MAF is flush with the surface. Reason: I had to put a new ring on, and it is just a smidge too big, but it feels like it is snugging on right.
Will the engine run if 1 plug is not firing?
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
nowakm99
Oct 9, 2015 07:10 AM
tgaffner
Sep 7, 2015 08:49 PM
rxwilly8
Sep 2, 2015 02:42 PM
