Mother Squeaker!
Old Jul 15, 2006 | 04:09 AM
aerospacediver's Avatar
Mother Squeaker!
I have a 2006 8 with about 4000 miles on it. About two weeks ago my clutch pedal spring started making a noise whenever I pressed or released it. It sounds like a kitten meowing. It was anoying but not enough to make a special trip to the dealer. I was just going to wait until I needed my next oil change. Just recently my shift boot started squeaking whenever I change gears. This has put a whole new perspective on it. So the clutch meows when I press it, my shift boot squeaks when I change gears, and my clutch meows again when I release it. Thats 1 squeak and two meows per gear change. That means 6 squeaks and 12 meows stand between me and getting to 6th gear. If I can not resolve this problem soon im going to post a DIY on how to remove your clutch pedal spring and shift boot with a shot gun. suggestions?
Old Jul 15, 2006 | 04:25 AM
take it to the dealer... and post only when you get it back....
or the shotgun thing sounds fun..
Old Jul 15, 2006 | 05:46 AM
btw,
i find this post very helpful.....
https://www.rx8club.com/series-i-trouble-shooting-95/help-strange-squeak-noise-94504/
Old Jul 15, 2006 | 06:31 AM
Thanks for the post but it is deff the spring and the actual shift boot. I work at best buy as a MECP so I know all about finding random rattles and noises. My problem is what to do to fix it.
Old Jul 15, 2006 | 08:57 AM
ucleadguitar's Avatar
6 spd Newbie
I had that same problem and the dealership replaced my clutch pedal and it's all gone now! Bring it to the dealer!
Old Jul 15, 2006 | 09:04 AM
mysql101's Avatar
"I have a 2006 8 with about 4000 miles on it. About two weeks ago my clutch pedal spring started making a noise whenever I pressed or released it. It sounds like a kitten meowing. It was anoying but not enough to make a special trip to the dealer. I was just going to wait until I needed my next oil change. Just recently my shift boot started squeaking whenever I change gears. This has put a whole new perspective on it. So the clutch meows when I press it, my shift boot squeaks when I change gears, and my clutch meows again when I release it. Thats 1 squeak and two meows per gear change. That means 6 squeaks and 12 meows stand between me and getting to 6th gear."
rofl!
Old Jul 15, 2006 | 09:48 AM
Clavius's Avatar
Its all about Style...
Might wanna take it to the dealer quick before your stearing wheel starts to Moo! hahaha stupid funny... its early and I laughed damn you all!~!!
Old Jul 15, 2006 | 10:34 AM
Easy_E1's Avatar
meow meow meow meow ,,meow meow meow meow ,sounds like a Meow Mix commercial.
Get that car to the dealer so they can remove that poor kitten from under your clutch pedal.
As for the squeak maybe a mouse? That would explain the kitten (looking for the mouse).
Old Jul 15, 2006 | 11:02 AM
zoom44's Avatar
hey aerospace where are you located? maybe one of these other guys can come help you fix itr? or at least we can find a competent dealer
Old Jul 15, 2006 | 07:54 PM
Auburn, AL. There is only one dealership within 60 miles. I will drop by and see what they say about it. As far as the shift boot goes I have no freakin idea. I dont know if its the leather itself rubbing together or insulation under the leather.... Im stumped.
Old Jul 15, 2006 | 08:05 PM
x1alpha's Avatar
LOL, just sounds so funny to me.
Old Jul 15, 2006 | 08:12 PM
Student Driver
My clutch spring squeeks (like a screendoor spring) when I depress my clutch...
Perhaps yours is doing the same thing...?
Next trip into the dealer I'll ask them to take a look...
They'll probably just spray it with WD-40...
Old Jul 15, 2006 | 10:35 PM
Ja, go to the dealer.
Easy fix. Better yet if you fixed it with a friend, then you can learn more about cars.
Old Jul 16, 2006 | 01:29 AM
yiksing's Avatar
the giant tastetickles
I got the shift boot squeak as well, I apply some autoglym leather cream. That eliminates it for 3 months after each application
Old Jul 16, 2006 | 10:46 PM
Talking
So apply four times and you're set for a year right?
Old Jul 20, 2006 | 01:22 PM
Philip_SA's Avatar
Rotary lover
I am in a way glad that i am not alone now
I also get the strange more of a squeek noise(can be spring) when pressing and depressing the clutch pedal, but then I also started to feel a roughness in the pedal (the feel trough the pedal in my foot) that feels as if it can be the thrust bearing maybe.
It feels rough and as if the bearing is on the way out and then the grinding is transmitted back with the brake fluid pressure to the pedal.
Can it be the thrust bearing?
I told the dealers, it must go for service next friday, they will check it then.
I drive a lot but all is long.......distance with less than half the clutch usage than a normal driver. I now have about 50000miles on
did anyone had this before?
Philip
Old Jul 20, 2006 | 02:06 PM
torbee's Avatar
My clutch pedal squeak makes more of a "reeeeeek" sound than a meow.
I'm due for an oil change in another 1,000 miles, so I'm planning on holding out until then.
michaelsk8er
Nov 9, 2015 07:06 AM
Shinka84
Aug 19, 2015 04:55 PM
Last_D8
Jul 2, 2009 11:54 PM
xxdevilzeroxx
RX-8 Show and Shine
Sep 7, 2004 03:11 PM
