View Full Version : Knight Sports final gear 4.777 with Autoexe Sports Clutch
coupe07
07-13-2006, 11:55 PM
Installed the Knight Sports final gear 4.777 coupled with Autoexe sports clutch.
Reviews:
1. Pick up is good.
2. Car feels more powerful, due to better biting from clutch and final gear. Howeve this is not a horsepower increase mod.
3. Cruising at higher rpm.
4. Petrol consumption still quite the same.
5. It is suitable for the 4AT as well. (One 4AT is fixing up soon. Wait for his reviews.)
6. Good mod for NA as low end torque is significantly better.
7. Value for money mod.
Conclusion:
SUperb combination. I have yet to try a final gear 4.777 with stock clutch system. I had the clutch up first before the final gear and its oredi feeling good. After the final drive, its another entirely different drive feel. Those thirsty for quick pick ups, this shld be wat u r looking for.
Again, above conclusion is based on my own setup on my car. U may or may not have the same experience.
artistknownasbush
07-14-2006, 03:12 AM
hey ivan, how much total btw?
Fab 8
07-14-2006, 06:45 AM
Sounds exactly like my FEED final drive with the MS clutch.
Genesis
07-15-2006, 03:45 PM
Bro, I thought you had the Autoexe sports clutch and flywheel installed months ago....what did I demo then?
cuscorex
07-16-2006, 12:34 AM
boss,mayb ur demo's was onli wif the clutch,w/o the final dr wks yet then...
sqflyer
07-16-2006, 02:15 AM
Heard a lot of works done on a lot of 8s liao... but nobody done any runs leh. Like dat how to know wat mods done wat? Sounds like it's high time for another session... heh heh.
rx8-8888
07-16-2006, 08:32 PM
coupe07, what is this final drive thing? care to explain more? which car component is this.. and how much does it cost? can use on 4AT rite? do you have stock for it?
coupe07
07-16-2006, 08:41 PM
yup u tried the clutch only. final drive was only done recently.
coupe07
07-16-2006, 08:42 PM
Sounds exactly like my FEED final drive with the MS clutch.MS shld be a lightened flywheel only, bro. MS have not come out with a clutch yet.
coupe07
07-16-2006, 08:45 PM
4AT yes.
Stock, yes.
my 1st post explains wat it does.
tems900
07-17-2006, 02:13 AM
Take a look at http://www.mazda.co.jp/mazdaspeed/news/2004/08.html, MS have it since Oct04, but u need to buy the flywheel individually & add up price slightly more expensive.
For Auto to use 4.777 final gear, make sure the manufacturer of e gear can be sure that it will not affect the torque converter in your auto gearbox as problem normally surface after a few mths of use. We just need some hero to try it first & post real life result of it.
coupe07
07-17-2006, 03:13 AM
For Auto to use 4.777 final gear, make sure the manufacturer of e gear can be sure that it will not affect the torque converter in your auto gearbox as problem normally surface after a few mths of use. We just need some hero to try it first & post real life result of it.we do not have heros for the 4AT but we have one rotary god who have tried and tested the final gear 4.777 on the rx8 and its proven problem free. :yumyum: :) :ylsuper:
One 4AT hero has stepped up liao.... hehehe
sqflyer
07-17-2006, 04:19 AM
tems, the MS clutch looks good. Any specs for it?
tems900
07-17-2006, 11:17 PM
Japan Rotary God ? S'pore hero "virus" ?
coupe07
07-17-2006, 11:37 PM
Japan Rotary God = Mr Isami Amemiya who owns RE AMEMIYA
S'pore Hero = Let him come out and post. But it is not Virus yet.
tems900
07-17-2006, 11:53 PM
RE, that great, i suppose they have tested e final gear for more than 6mths, 1 or 2 yrs to be sure, problems will not surface only after maybe >8 mths, not a lot of aftermarket will give any warranty, if want to have e fun just do it, look at FI people, can't work take out & waste e $ that all, RX8 torque converter worth $$$$ ? i not sure also
gfoo
07-18-2006, 01:59 AM
tems, are you then implying that it's almost a certainty that Autos that install the final gear will run into problems in time to come?
mkl22
07-18-2006, 02:54 AM
i think tems is being cautious. as the auto trans is pretty complex. reading thru the diagnostic guide for the transmission can faint. it takes into consideration a whole host of parameters to determine shift quality and speed of shift. so it might affect but i would doubt so.
wondering if anyone has used smaller tires and rims to replicate the change in the final drive?
gfoo
07-18-2006, 02:59 AM
i think for sure the diff between 16" and 18" is there. car felt more sluggish when i moved from stock 16" to 18" wheels....
tems900
07-18-2006, 03:28 AM
i not sure whether e final gear will cause any problem to e auto gear box or torque converter ? some S'pore 8 owner need to try it & tell e truth after some mths of use, but until now i only read from internet that to mod an auto gearbox mechanically, most people will chose to change to a better performance torque converter or flywheel but not a lot of aftermarket maker do that & for auto 8, i dun think so at e moment
derekwcw
07-18-2006, 03:32 AM
Correct me if I am wrong, but I don't think in the auto there is a flywheel, rite? :Peace:
tems900
07-18-2006, 03:46 AM
should be call ringgear not flywheel & i think is connected or assemble to e torque converter
gfoo
07-18-2006, 10:38 PM
Honestly, i've yet to read anywhere that modding the FD on an auto causes probs in the tranny. Granted an auto tranny is complicated, but as the mod is done on the differential and not the main tranny, i can't see how it could affect it that much, especially when the ratio diff is .333 or so.
Perhaps someone could post a link to a thread somewhere that discusses post FD on auto probs (any make, not just the rx8)
tems900
07-19-2006, 12:04 AM
As what u had said, i also have not read anything on e net regarding modding final gear on auto trans. of any make of car, or i know anybody had done that, i think soon somebody can post that since that a real life rx8 exp. & some other make of car owner can benefit from that exp. also
KJ238
07-19-2006, 01:06 AM
May i know what the pricing looks like?
tan280
07-20-2006, 07:13 AM
Thanks to Ivan and guys @ Monster Garage, the very 1st auto in Singapore to be equipped with the Knight Sports Final Drive 4.777 is finally out today and the job is done within one day... as I had not really test the final drive, I do not know how good it is [although the guys said is way beyond our imaginations for the sharp accel and revving it high], I will post my review once I get of the car hopefully by tomorrow [now relocating something la].. stay sharp for the review for those who is going to install and also considering one...
Alternatively for those who is coming to the official opening of Monster Garage, can ask either me or Ivan for more details... cheers bros!!! :ylsuper: :ylsuper: :ylsuper:
jaii13
03-21-2007, 11:04 PM
*bump*
Instead of starting a new thread, thought I'd bump this instead. Coupe07, your review of the final drive is informative. What's your take on the AutoExe clutch? How does it perform in normal and hard driving? Thanks.
coupe07
03-22-2007, 12:18 AM
*bump*
single plate, silent, and bite is very good. A street clutch and easy to drive....
Stephy88
03-23-2007, 08:30 AM
Zoom Zoom...
VERSUS4582
06-19-2009, 07:27 AM
Where did you buy the final drive from???please respond man...thank you...
CKZ
06-20-2009, 10:58 PM
Where are you situated? So that we can help you accordingly
rx8thunder
06-20-2009, 11:10 PM
Buy an 09 4.777 diff from mazda dealer
csl
06-21-2009, 12:21 AM
In Singapore = please pm coupe7 (Monster garage)
in Malaysia = ST-Wangan, Sunway. (www.stwangan.com)
Other place? japanparts.com :):):)
VERSUS4582
06-21-2009, 04:30 AM
I live in cyprus,europe...can i buy direct from knight sports australia?is there an online shop that sells it?which is better,the feed or the knight sports final??i am aware that japan parts have it(feed at least)but they are the most expensive online shop everrrrrrr!!!!!!!!!
csl
06-21-2009, 06:35 PM
Both company I mentioned above did sell parts almost or the same as KS in Japan. Try to contact them if they wanted to deal with international customer.
CKZ
06-22-2009, 06:03 AM
If you feel Japan parts is expensive please contact KS directly see how can they help you.
