Help, Coolant level light on, heat feeled.
Old Jul 10, 2006 | 12:15 PM
theboy's Avatar
RX8 newbie!
my car is type E, auto. my coolant level indicator light is on.
i think my fan is not working?
but the water level is full, temp indicator doesn't show it overheating.
i can feel the heat. it make my car smells.
Old Jul 10, 2006 | 07:31 PM
virus's Avatar
it could be the coolant sensor being damage...i have the same experience. bring to a garage ... i think they can fix it up for u ........if still persist...get a new coolant reservior.
Old Jul 11, 2006 | 08:13 AM
theboy's Avatar
RX8 newbie!
Thanks. flushed my car 3 times. and i think u are right.
Old Jul 11, 2006 | 08:45 AM
foo77's Avatar
4th batch : Apr 03'
it happened to me once,i'm just surprise because the car still new,so i just drain it and refill with new coolant,after that the indicator light never show up
Old Jul 11, 2006 | 09:03 AM
theboy's Avatar
RX8 newbie!
i drain it 3 times. but still the same oh. damn.
Old Jul 11, 2006 | 11:01 AM
lennon's Avatar
Dont drain it anymore....... New coolant can damage gasket....
Old Jul 11, 2006 | 09:33 PM
theboy's Avatar
RX8 newbie!
ok. today i will try to change my engine oil. and see whether there is any effect or not. the light is on after i drive a while. i was thinking. was the sencor defected? cause 1. i put too mcuh coolant. 2. i put cold water in a hot tank before.
Old Jul 12, 2006 | 07:48 AM
theboy's Avatar
RX8 newbie!
OK! problem solved! the sencor is dirty!!!! WTF!!!! Scare me to hell! took off the sencor and cleaned it. and do u know how much u need to take off before u can see it???
Old Jul 12, 2006 | 12:00 PM
Zero_Rotary's Avatar
Double 8
Smile
ayoooo whats up with your engine bay bro?
u always drive on dirty roads ha?
im glad ur prob is solved
Old Jul 12, 2006 | 05:35 PM
theboy's Avatar
RX8 newbie!
ya lo. i always drive on dirty road, even rain i also drive.
Old Jan 26, 2009 | 12:51 PM
hawkwind's Avatar
is that the probe on the left on the second photo. as i have the same problem.
Old Jan 27, 2009 | 10:19 PM
PitchBlaC's Avatar
Huh. The sensor can be taken out? Was told that the sensor and the coolant tank comes together. x|
Most of the ppl here would have most probably replace the whole tank. Pls post again if the coolant light did not light up again for the next 1-2 weeks. A million thanks.
Old Jan 29, 2009 | 08:28 AM
csl's Avatar
csl
Not the reed switch but the magnetic float that in the tank failed to float anymore. You can either make a external sensor assembly or replace the tank.
Old Jan 29, 2009 | 08:54 AM
foo77's Avatar
4th batch : Apr 03'
^ +1 about the magnetic float that in the tank failed to float anymore
For info its not about the sensor being replace because i've tried it before and still not working.. solution is just buy a new water tank
anyway here's how it look like a new sensor inside our water tank
Old Jan 30, 2009 | 11:36 AM
csl's Avatar
csl
Most probably only blackjax and caspel had seen my self made external water level sensor assembly (last visit to singapore ) The reed switch is very cheap and can get from most electrical shop. I though is the reed switch problem too at the beginning. But after several testing, found the real problem is the float. The reason i don't wanna buy the ori tank is because I felt a bit toolan of the original tank quality for such an amount of $$. No guaranty on solving the problem permanently. So I just get some water heater parts, reed switch, some cooper piping + brass fitting and hoses, to made something bolt on, to give the water level signal to the car.
Old Mar 16, 2009 | 05:46 AM
foo77's Avatar
4th batch : Apr 03'
^ any pics of it? coz my friend have changed twice.. sound more like power steering failure, change and then fail again after thousand miles
Old Apr 17, 2009 | 03:50 PM
csl's Avatar
csl
Ultimate solution is coming (hopefully will come out on July after beta test)
Old Apr 20, 2009 | 06:08 AM
foo77's Avatar
4th batch : Apr 03'
sound good, i'll wait for that
Old Apr 20, 2009 | 08:52 AM
csl's Avatar
csl
Currently I met a bottle neck, that, how to make the cost as low as possible Material and certified TIG welding services are already expensive. Some more need to do helium detection leak test (normally 100 psi). The sensor rated at 140 celcius safe working temp and need to design something to make it works although coolant temp reach 150c (no problem on design but only higher cost), DIY removable, serviceable, repairable sensor assembly design face the cost problem as well. A lot of things need CNC made in stead of just put few plate together and weld on . I know it is not necessary but I don't wanna come out with something that just reach the guessing tolerance or just enough to solve the problem in a short term basis. I want something that rated beyond specification, and will be a permanent solution.
drebbrnator
Dec 27, 2018 07:02 PM
Nisaja
Aug 6, 2015 01:27 AM
dmac1961
Jul 24, 2015 11:27 AM
