MS CAI install Engine Wolnt stay running
Old Jul 8, 2006 | 04:18 PM
baysj's Avatar
After installing the MS CAI I tried to start the engine, it starts normally then begins to sputter then stalls? Anyone have any ideas? I checked the nipple on the vacume tube going into the throttle body. Thanks in advance..
Old Jul 8, 2006 | 04:29 PM
baysj's Avatar
I removed the MAF harness from the instake and the car starts and runs fine. I also reset the ECU. Im Confused.
Old Jul 8, 2006 | 05:44 PM
baysj's Avatar
I figured it out, the MAF bung was welded on upside down.
Old Jul 8, 2006 | 05:49 PM
cgrx's Avatar
DRIVEN
thats retarded
Good catch
Old Jul 8, 2006 | 05:56 PM
baysj's Avatar
does anyone see an isse with running without the MAF sensor connected? the car is 10 miles from my hosue. I just want to get it home
Old Jul 8, 2006 | 06:43 PM
StealthTL's Avatar
Metatron
Arrow Put it in....
I would put it in somehow. Seal it as best you can, duct tape, bubble gum etc. just so long as it's (mostly) in the airflow, and facing the right way!
....or put the stock piece back on...
S
Old Jul 8, 2006 | 06:59 PM
baysj's Avatar
my understanding is the car will go into safe mode with it in upside down and disconnected and run rich is this true?
Old Jul 8, 2006 | 07:24 PM
cgrx's Avatar
DRIVEN
Duct tape it. you should be fine for the short trip
bitch out MS too
Old Jul 12, 2006 | 06:02 PM
Mafia's Avatar
My MS Cai is running fine and sounds great. MAF is in and i installed the thing myself. Maybe you just got an intake built ona friday..
Old Jul 13, 2006 | 12:29 AM
Imidazole's Avatar
Retarded mistake.
Old Jul 13, 2006 | 06:31 AM
LostAngel's Avatar
Mine works too...
vapor2
Nov 3, 2020 03:38 PM
ktec
Jul 29, 2015 01:17 PM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
