View Poll Results: optima battery you use/recomend?
Red top 75/35
5.00%
Red top 34R
25.00%
Red top 35
10.00%
Red top 51R
5.00%
Yellow top 51R
20.00%
Yellow top 35
5.00%
Yellow top 34R
15.00%
Other...
15.00%
Voters: 20. You may not vote on this poll
Optima Batteries
Old Jun 22, 2006 | 10:47 AM
LiL BenNy's Avatar
Bubblicious? DEF.
Optima Batteries
Which battery do you use/recomend?
and whats the differences in like34, 51 etc what do the numbers mean?
Old Jun 23, 2006 | 07:36 PM
LiL BenNy's Avatar
Bubblicious? DEF.
bump bump bump
Old Jun 23, 2006 | 07:47 PM
MazdaManiac's Avatar
I'm using a yellow-top group 34. It rocks. I live in an oven, so the OEM battery went south almost immediately. The Optima gave ma a ton of additional cranking sped which gets the motor started really quick.
Plus, I can run all of my A/V stuff at shows for hours instead of minutes.
The "group" designation refers to the fitment - where the terminals are located, their orientation and the physical size of the battery.
Optima doesn't have a battery that they spec for the RX-8, so if you use the group 34, you will have to extend the positive terminal with an inch or so of aluminum bar stock to reach the (+) terminal.
The negative will fit just fine.
This is because the group 34 is physically backwards compare to the OEM battery.
Old Jun 25, 2006 | 10:25 AM
LiL BenNy's Avatar
Bubblicious? DEF.
if i got a yt 34r it would be the same except reverse do i wouldnt have to extend the pos terminal?
Old Jun 28, 2006 | 04:20 PM
LiL BenNy's Avatar
Bubblicious? DEF.
more recommendations??
Old Nov 17, 2007 | 02:17 PM
gothmogthebalrog's Avatar
Rotary Stall Out
not quite dead yet...
After a good bit of research and calling practically all of the Delaware parts shops I found the D51 yellowtop optima fits our cars perfectly. The batteries come with a little tray attached to to top of the batt, it clips underneath the battery and puts it at the perfect height- no extending cables, the battery clamp goes back on, no wiggling around in the batt box, basically a perfect fit and match. my 8 flooded and I ran down the stock battery in about 2 minutes- went out picked up the D51 dropped it in and IMMEDIATELY the car started up from the quicker rollover of the starter. I plan on adding more AV and this was worth the money.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
