pullies pullies
Old Jun 22, 2006 | 09:56 AM
cameron36's Avatar
pullies pullies
I been looking for a pulley kit and I just dont know I been seeing greddy and others for around $150 but then I found these wide pulley kits on SR motorsports for around $450 I really dont know what to do.. I like greddy but there has got to be some kind of difference in the kits. please help me find a pulley kit with the best performance and best bang for the buck.
Old Jun 22, 2006 | 10:15 AM
Former A4'er's Avatar
WTF?
Check this thread out https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/pulley-pulleys-pulleys-90154/
I have the SR Pullies, I don't know if I gained any HP but they look nice and match my Revi intake.
They're other sets for cheaper out there.
Old Jun 22, 2006 | 10:21 AM
JRichter's Avatar
Void Where Prohibited
Search, I see three threads on pullies just on this page...
Old Jun 22, 2006 | 01:16 PM
JB_Rotary's Avatar
Always lurking
Here https://www.rx8club.com/forumdisplay.php?f=23 and read the sticky at the top it will take you to pullies
Old Jun 22, 2006 | 02:43 PM
staticlag's Avatar
The Professor
Agency Power seems like best bang for the buck
Old Jun 22, 2006 | 05:17 PM
Brettus's Avatar
Boosted Kiwi
not totally sure about this but from what I read - only pullies with underdrive will give you any hp increase . The stock pullies are pretty light alrerady. The agency power is good value because it is just the crankshaft pulley .
Old Jun 22, 2006 | 10:16 PM
Fanman's Avatar
Do yourself a favor and stay away from SR Motorsports pullies. I dynoed them, and got all of 1 hp gain, and have had a few issues pop up because of them.
Old Jun 23, 2006 | 01:59 AM
flyboi1121's Avatar
werD?
i just installed the agency power pulley.. it's awesome, cheap, and fun to install. also... my ac is still cold =D
Old Jun 23, 2006 | 08:54 AM
cameron36's Avatar
how about mazdaspeed pullies???? are those any good????
Old Jun 23, 2006 | 09:48 AM
JB_Rotary's Avatar
Always lurking
I didn't know Madaspeed made pullies or are you thinking about the speed source pullies from mazdaracing? Thoose supposedly give you 10+hp and eliminate your AC. I think Teamrx8 has them.
Old Jun 23, 2006 | 10:07 AM
cameron36's Avatar
I looked at the agency pulley set and seen them for $150 but then there is a unorthodox pulley set on the site that says they are better for around $350 I really have no clue if this is true or not.
Old Jun 23, 2006 | 03:46 PM
whenson417's Avatar
Why don't you go get your car dyno'd then buy the unorthodox pulley and then dyno your car again and post the charts so we can see what unorthodox pulleys will do. I did that with the Agency pulley and got a ton of low end hp gain. I am curious to see if the unorthodox set does any better since they lighten up the other pulleys as well.
Old Jun 23, 2006 | 04:08 PM
Jaguar_MBA's Avatar
I have the SR Motorsports pullies on my RX-8. If you must get Pullies, I would suggest UR ones and save yourself a couple of hundred dollars.
On a regular piston car these work just fine because they have a heavy harmonic balancer. The RX-8 does not. Reducing weight on the crank shaft increases HP to the rear wheels...or reduces inefficiencies that reduce HP from the Rear Wheels. A standard harmonic balance on my 1992 300zx must have weighed ~ 21lbs and I replaced that with an aluminum unit that weighed ~ 4-5lbs or so. That is where the performance gain is to be had. RX8's underdrive crank pulley must weight ~ 1.25lb stock.
Old Jun 23, 2006 | 04:33 PM
FastRX8's Avatar
IstanbulNotConstantinople
I think this is a "Did Not Search" record!
The first post in this section is a sticky with the word "Pulleys" in it.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/calling-all-springs-flywheels-sway-bars-intakes-pulleys-more-90832/
Please, let's try to keep the info in one thread.
https://www.rx8club.com/showthread.php?t=90154
200.mph
Dec 10, 2018 03:49 PM
iSki123
Jul 27, 2015 12:41 PM
katana4eva
Australia/New Zealand Forum
9
Jul 9, 2007 04:00 AM
BLOWN8
15
Nov 3, 2004 08:20 AM
