Car has power, but nothing works
Old Jun 19, 2006 | 10:28 PM
Moostafa29's Avatar
Storm Trooper
Exclamation Car has power, but nothing works
Well I finally got my car back, so I wanted to start removing the gauges, boost controller, and turbo timer. I started with the gauges, and everything was fine. I then removed the boost controller, and wanted to move the car real quick, but when I went to turn the key, nothing happened. I was thinking that since I wired it to the same source as the turbo timer, I could remove that, and everything would be fine. I took everything off around the ignition, and immobilizer area, and tried again. Still nothing. I thought that perhaps after all that, it was something as simple as a fuse, I looked and saw that my main power fuse was blown. I went ahead, and replaced that today, thinking it would solve the problem, and that still didn't do anything. Whats weird is that the little light inside the dash blinks like normal, and I could lock and unlock the doors just fine, but nothing else works. Now I've run out of options, and have no idea what the problem could be. I really don't want to have my car towed for the 5th time this year, so any advice or suggestions would be appreciated. Thanks!
Old Jun 20, 2006 | 06:10 AM
chrism's Avatar
Misfit Moderator TnC
something similar happened to me last year....it was a relay in the fuse box under the hood
Old Jun 20, 2006 | 06:56 AM
DOMINION's Avatar
I don't buy Kool-Aid
Moostafa29 you got Greddy?
Old Jun 20, 2006 | 06:59 AM
Moostafa29's Avatar
Storm Trooper
Which one?
Old Jun 20, 2006 | 07:06 AM
Moostafa29's Avatar
Storm Trooper
I'm back to NA now.
Old Jun 20, 2006 | 07:35 AM
Moostafa29's Avatar
Storm Trooper
I prayed on it, and the answer came to me last night. It was the ignition key fuse. All is well. Hopefully I can go a few weeks without something else happening.
Old Jun 20, 2006 | 06:51 PM
rxeightr's Avatar
M0D Squad -charter member
And some doubt the power of prayer.
Jesus Martinez
44
May 6, 2025 08:09 AM
delicious_dallan
Jan 17, 2020 09:17 AM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
CMRine04
Jul 29, 2015 02:07 PM
AussieGray
Jul 16, 2015 03:58 AM
