elbow keep pushing Bin Cover in, is this a common problem??
Old Jun 19, 2006 | 02:50 AM
dying_here's Avatar
Im not sure if you guys also experience this "problem".. but every now and then I seem to put too much pressure on the front Bin cover ( arm rest?) so that it is slightly off the sliding track and I have to use a little force to push it back up when I realize that it isstuck.
Not only is this annoying but in the long term the sliding mechanism will probably break.
do you guys also experience this? or is my arm just too heavy?
Old Jun 19, 2006 | 02:54 AM
REMillers's Avatar
Hmm wow thats a new one, course I'm only around 150 soaking wet so probably don't even come close to puttting a lot of pressure on it.
Would try to avoid it though, maybe take the loving to the rear of the car...less strain on the center console back there
Old Jun 19, 2006 | 02:56 AM
shakRpahX8's Avatar
Unknown
I drive with it opened =]
Old Jun 19, 2006 | 02:57 AM
The Ace's Avatar
Greek Power
Happens to me all the time....
It appears that the sliding tracks are a bit weak and shallow. Thus the rails come off-track.....and you need to push them in.....don't think it's serious....
Old Jun 19, 2006 | 04:57 AM
DOMINION's Avatar
I don't buy Kool-Aid
Me too and I leave it open
Old Jun 19, 2006 | 06:45 AM
Spin9k's Avatar
Momentum Keeps Me Going
Design problem.... there's a little piece of plastic clip that'll break after this happens a few times...then it won't close right anymore. Replaced x2 under warranty already.
Old Jun 19, 2006 | 10:48 AM
Tamas's Avatar
Registered Lunatic
Happens all the time here as well.
Old Jun 19, 2006 | 10:54 AM
XRX8X's Avatar
more then a Mazda
happened x2 for me no matter how easy you lean on it .after a while the little plastic breaks lose and it's sliding back and forth(160LBS SOAKED) i do not lean on it hard at all i think it's one of those weak points that was not looked at by design.wro,wro,wro,!!
Old Jun 19, 2006 | 03:05 PM
Asmoran's Avatar
I have a habit of putting my wieght on it (190lbs) getting in and out of the car. After a couple weeks of this, a little plastic clip broke from the underneath the lid. I don't think the clip broke, i think it was the plastic that the clip clips into.
Anyways, it still closes just fine, and now that it's broken I don't have any problems with it at all. And I've had the car since August (clip broke a couple weeks after I bought it, never bothered with getting it repaired).
Old Jun 20, 2006 | 09:25 AM
Huey52's Avatar
Registered Zoom Zoomer
Happens to me too. My only other complaint is the tailight internal condensation. Both warranty items. Even with the clip broken the sliding/latching function is fine, but you do get the weight on elbow induced movement.
The on/off function of the oil gauge, vs. a true pressure readout, is a minor item as well.
Old Jun 21, 2006 | 09:11 AM
yiksing's Avatar
the giant tastetickles
I always have both hands on the steering so its not a problem for me
Old Jun 21, 2006 | 09:58 AM
reaper1's Avatar
Not a problem. Left hand on stering wheel, Right hand on stick not a problem so far. If you lean back a little it might help.
Old Jun 21, 2006 | 10:57 AM
dmc27's Avatar
doin' the bull dance
All the time. I generally check it before opening to make sure it is properly aligned. I'm sure it will break eventually.
Old Jun 21, 2006 | 11:48 AM
Glyphon's Avatar
脾臓が痛みました
i lean on mine all the time, don't haven't this problem since the first week i had the car. basically its not the amount of force that's being put on it, its the direction of the force that's causing the problem. leaning straight down on it, there is no problem, but if you put any sort of sideways pressure on it, it can come off the track. basically, the times this happens is getting in and out of the car, like asmoran said he does. just try to pay attention at those times, and it will eventually become a learned behavior, and you won't have to think about it anymore. and the problem will stop too.
Old Jun 21, 2006 | 11:55 AM
dying_here's Avatar
Its good to know Im not the only one, looks like I should try to break it and get it replaced before the warranty expires
I find it very uncomfortable to drive with the Bin Open or with any sort of beverages in the cup holder
Old Jun 21, 2006 | 12:27 PM
Glyphon's Avatar
脾臓が痛みました
cups go in the back
xAgyex
Jun 3, 2026 03:47 PM
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
projectr13b
Aug 28, 2015 09:24 AM
Solmors
Aug 21, 2015 10:11 PM
