Track Day!
Old Jun 18, 2006 | 01:31 PM
mwaters's Avatar
Track Day!
Am a new member of this club, have done some SCCA racing in a Spec Racer, and have a 2005 RX-8 with about 11000 miles on it. Am taking the RX-8 to Virginia International Raceway in a few weeks and will have a couple of track days. Could someone help with these questions?
- Does the RX-8 have an MPH limiter? If so, can we disconnect?
- Any easy tricks to boost the performance on the track, either power or handling
- Traction Control on the car: does it err on the side of "too slow", and what will I lose if I shut it off?
- Any other prep recomendations you can make?
- Any concerns (beyond normal) with a couple days of hard driving for this car?
Thanks in advance for your comments! Am looking forward for a little Zoom Zoom!
mwaters
Old Jun 18, 2006 | 02:32 PM
NoTears316's Avatar
Shock and Awe
No limiter...
Click Me
Old Jun 18, 2006 | 04:41 PM
alnielsen's Avatar
There isn't a limiter on the car. On most tracks you won't get near the top speed of the car. Road America or a 2 mi oval would be the exeptions.
Traction Control: Try it for a few laps on to get a feel for the car, after that turn it off and have fun.
The best mod is to get rid of the OEM Bridgestone Potenza tires. I like the Falken ST615's in 245/40X18.
There are many threads here about tires and brake pads. Start reading.
Old Jun 18, 2006 | 06:18 PM
I would go for sway bars with ends kinks.
Old Jun 18, 2006 | 10:23 PM
BlueRenesis82's Avatar
Registered Tracker
make sure that you have enough oil, wouldnt want to run out and turn your engine into a paperweight
Old Jun 18, 2006 | 11:17 PM
8 lover in Japan's Avatar
just the basics which you proabably know already
=good tyres at the right pressure (this is crucial)
=good brake pads
=high octane fuel
=take oil, tools, coolant, water, brake/clutch fluid, spare tyres (if you geta bit tail happy)
TIPS
=if your engines temp goes up, turn on the fan heater in the cabin(this helps to disperse the heat, itll be a sauna in there though)
=don't run with you a/c on
=tape over the seams in your body at the front eg. headlights, hood, (this helps to reduce drag)
=have your windows up (this is a safety precaution aswell as reducing drag)
=practice heel and toe downshifting
these are just my few tips...hope it helps!!
yoroskiku
Old Jun 18, 2006 | 11:57 PM
Registered Tracker
yoroskiku
actually most clubs that have track days in the US require you to have the windows down
Old Jun 19, 2006 | 06:28 AM
mwaters's Avatar
Thanks for the advice everyone...I will have to make a decsion about the tires. I have the OEM Dunlops now. Not sure I will have the time have a set of Falkens mounted to a new set of wheels.....
Thanks,
mwaters
Old Jun 19, 2006 | 09:14 AM
Go48's Avatar
Keep your fuel tank at least 1/2 full or you may run into fuel pickup problems on fast lefthanders. You can read about the problem here on the forum. It's a known problem with the RX-8, but the problem is not unique to the RX-8, however.
Edit: BTW, I just came back from a 2-day MDA event at VIR and you will LOVE the track if you have never been there before. Amazing track, great facilities.
Old Jun 19, 2006 | 09:56 AM
Rootski's Avatar
DGAF
https://www.rx8club.com/showpost.php...86&postcount=5
I have that post bookmarked. Lots of great info on track days.
Old Jun 19, 2006 | 10:29 AM
limepro's Avatar
the book that came with my car says the limiter is set at 147
Old Jun 19, 2006 | 10:33 AM
JB_Rotary's Avatar
Always lurking
The book probably lied
20b-3rotor
Sep 2, 2015 08:54 AM
wayloco
Sep 1, 2015 09:03 PM
