Drive-up Ramp for Oil Change
Old Jun 15, 2006 | 02:54 PM
ArthurY's Avatar
I've been using a pair of steel-based portable drive-up ramps to change the engine oil for all of my vehicles in between the annual shop-services. I seriously doubt I can drive up my RX-8 on these ramps because the front spoiler is way too low for this to happen.
What equipment do you guys use to change the oil on your RX-8? Do you know of any drive-up metal ramps that can do this or do you use two jacks instead?
Please share your thots on this. Thanks!
Old Jun 15, 2006 | 03:12 PM
Go48's Avatar
Jack up the passenger side, remove the front wheel, remove the drain plug, lower the passenger side so that all the oil drains from the pan. R&R the oil filter, jack up the car again, replace the drain plug, replace the wheel, lower the car and fill with oil. It's smart to use a jack stand for safety while you are under the car.
Old Jun 15, 2006 | 04:21 PM
DynamicDookie's Avatar
http://www.sp-power.com/catalog/prod...oducts_id=3384
these plus jackstands. they're pricey, but worth it especially if:
1) you work on you car a lot
2) are lowered
3) have the MS body
Old Jun 15, 2006 | 05:19 PM
Glyphon's Avatar
脾臓が痛みました
2) are lowered
3) have the MS body
i have something similar to those. they are made out of 2x8s. my dad made them back when i was in highschool, and now they have a pickup and a suv, and they don't need them anymore, so i got them. the work really well too.
look a bit like this (quick and dirty drawing):
why isn't this showing up as an image? i used the image tags.
Old Jun 15, 2006 | 05:33 PM
SC-ed's Avatar
HTML is disabled for the DIY forum. You have to attach the pics.
BTW I use almost the same DIY ramps made from 2x10's. They are 8 feet long, 12" high. I'll post a picture when I get the car on them for HF cat installation next week.
Old Jun 15, 2006 | 10:18 PM
ArthurY's Avatar
Thanks, DynamicDookie, are these Takata ramps made of steel? Are they safe?
Old Jun 15, 2006 | 10:30 PM
NgoRX8's Avatar
hmm.. maybe i should get those things. i always drive up on 2x4s and use the supplied jack in our car.
Old Jun 15, 2006 | 11:34 PM
toxin440's Avatar
hah I can beat you ALL!
I have the Fumoto Quick oil drain release plug and have discovered that when I chance my oil I do not need ramps or anything, just park the car turn the wheel ALL the way to the left and then there is plenty of room (my long arms help) to reach the drain valve and unhook/turn it PRESTO oil changed in 5 minutes! :-D
Old Jun 18, 2006 | 10:50 PM
ArthurY's Avatar
I'll have to try that. Thanks!
Old Jun 19, 2006 | 07:48 PM
expo1's Avatar
He's as bad as Can
I got tired of the sliding Ryno’s and also made my own. Easy to drive up and they stay put. These are not cheaper than Ryno ramps and are MUCH heavier but work much better for me. I got the idea from here. I added an extra 2 X 8 and wheels to mine.
Attached Thumbnails Drive-up Ramp for Oil Change-100_3692.jpg   Drive-up Ramp for Oil Change-100_3691.jpg
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
RotaryRider
Jul 20, 2015 07:05 AM
