Ok where is the odometer button
Old Jun 14, 2006 | 11:56 PM
p-trix's Avatar
I have lost my rx8 book and I want to reset my ecu.. where is the odometer button..I know its a dumb question..thanks
Old Jun 15, 2006 | 12:13 AM
Stavesacre21's Avatar
1.21 Jiggawatts
Um....you can reset the TRIP counter by pushing the black button above the display gauges...but it's unlikely you'll be resetting the ECU or odometer with it...
There are 2 buttons above the gauges (one on each side), one switches between A and B trip, and the other, if you hold for a couple seconds, will reset the trip counter.
Old Jun 15, 2006 | 12:17 AM
presequel's Avatar
ay bay bay
it took me a while to see them too, especially at night. they really blend in.
Old Jun 15, 2006 | 08:52 AM
puch96's Avatar
I believe the one on the right switches between A and B trip, and if you hold it down it resets the trip counter. The one on the left, if you hold it ddwn it switches between mph and Kmph.
Old Jun 15, 2006 | 09:46 AM
Aseras's Avatar
hold down the right button, turn key on and keep holding until trip meter says test... turn key off. turn key back on and stomp the brake pedal about 20 times until the oil gauge moves and then everythig is reset.
Old Jun 15, 2006 | 10:27 AM
Glyphon's Avatar
脾臓が痛みました
the trip od reset button is used in clearing stored data from the ecu. look above to see the procedure for doing this.
Old Jun 15, 2006 | 10:29 AM
MazdaManiac's Avatar
Attached Thumbnails Ok where is the odometer button-iviewcapture_date_15_06_2006_time_08_24_50.jpg
Old Jun 15, 2006 | 11:24 AM
Glyphon's Avatar
脾臓が痛みました
and here's the manaual...
http://www.mazdausa.com/MusaWeb/pdf/...004_owners.pdf
Old Jun 15, 2006 | 11:34 AM
BullitHockey's Avatar
7 speed
yeah i know what you mean when you say that they blend in
Old Jun 15, 2006 | 12:42 PM
Brice-RX8's Avatar
Stomping the brake pedal is only going to clear the KAM memory.
Pushing the trip button while you turn the ignition to on doesn't clear anything but the diagnostic information that is in the guage cluster. As far as I know the fuel trims and other information is only reset with unhooking the battery.
Old Jun 15, 2006 | 12:52 PM
Glyphon's Avatar
脾臓が痛みました
Originally Posted by MazdaManiac
That won't clear the KAM and can do some other funky things if it isn't complete. It will also erase your radio presets and clock settings.
There are two reset procedures, one for the NVRAM and the other for the KAM. Neither will erase your radio presets and such like the method SpooledUp7 posted:
1) With the key in the off position, press and hold the odometer reset button and turn the key to on;
Continue to hold the odo button until the odometer reads "TEST" and then release.
2) Turn the key to off and repeat step one.
This will reset the entire PCM except the KAM which contains the sensor profiles amongst other things. You can reset it with the familiar procedure:
1) Turn the key to on
2) Depress the brake pedal rapidly 20 times in a row until the oil pressure gauge sweeps to halfway and back again.
NVRAM stores continuos engine data like fuel trim and code situations.
KAM stores sensor profiles and the actual MIL codes.
Old Jun 15, 2006 | 01:16 PM
Brice-RX8's Avatar
I could be wrong but I have never seen a car that will let you reset the ECU via this method. I had a SVT Focus that would allow the same activities via the trip meter button, but it would not reset the ECU when doing so.
Old Jun 15, 2006 | 01:25 PM
Glyphon's Avatar
脾臓が痛みました
well, i don't have a scananlyzer, so i can't verify it myselft, so i'm just going to have to take mazdamaniac's word for it...and if there was someone's word on the forum i'd trust about this car, his would definately be one of them.
not trying to dig on you, or how much you know about the car. just saying that jeff knows his ****.
Old Jun 15, 2006 | 01:31 PM
Brice-RX8's Avatar
^^ Oh I know he does, and is one of the most knowledgable guys on this forum. I just wonder if he or anyone else has tested to make sure that is ready does this, never seen offical documentation about it like the KAM reset process, that is all.
Old Jun 15, 2006 | 08:46 PM
1.21 Jiggawatts
This is indeed the weirdest meathod i've EVER heard of for resetting an ECU
Guess i'm used to the 90's fords where you just unplug that battery and stand on the brake for 10 seconds....hmm
Old Mar 30, 2013 | 05:01 AM
Paco664's Avatar
Thank you very much for this...
Iknow it sounds silly but I spent 10 mins looking for this before finding this....
Old Mar 30, 2013 | 02:14 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Holy 7-year thread bump!!!
Old Apr 19, 2021 | 10:25 AM
Maritza Soto's Avatar
Ok....
Those are some really tiny buttons lol
QUOTE=p-trix;1407103]I have lost my rx8 book and I want to reset my ecu.. where is the odometer button..I know its a dumb question..thanks[/QUOTE]
ok
Old Jul 17, 2025 | 07:49 AM
DocFoster's Avatar
Reset trip
I literally had to search for frickstick ever to find this stupid button. None of the threads I looked at anywhere could tell me where this was. But on a 2004 Mazda RX-8 and maybe others I don't know, the little button is hidden in the dark shadows above the instrument panel. There's one in the dark shadows near gollum on the right and one hidden in the dark shadows near smeagol on the left, pinpoint center above the instrument panel circles trinity.
DJSensation
Jan 1, 2012 10:42 PM
rotaryPilot
Feb 4, 2008 01:56 PM
Myardor
Dec 6, 2007 01:13 AM
Rx-8 TT
17
Jul 2, 2006 06:25 PM
kraji
Sep 13, 2005 08:18 PM
