Behold The Fishy Smell Has Been Unveiled!!!
Old Jun 10, 2006 | 11:56 AM
DOMINION's Avatar
I don't buy Kool-Aid
Its your A/C lol I was just in 3 new rental cars and all of them smelled like fish after I ran the A/C. Well I just got my 8 back Friday and guess what it smells like fish now . I was like
Old Jun 10, 2006 | 12:04 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
3 rental cars and now your RX-8 smells fishy?????
I think there is an antibiotic that can clear that up.........
Old Jun 10, 2006 | 12:11 PM
DOMINION's Avatar
smart ***
Old Jun 10, 2006 | 12:12 PM
tiggerlee's Avatar
May Cause Anal Leakage
prolly just your breath blowing back in your face.
Two words. Breath mints.
Old Jun 10, 2006 | 12:26 PM
DOMINION's Avatar
Tryed that. Did not work. I even tryed rolling in Vaseline but that did not help cuz I could not open my door
Old Jun 10, 2006 | 03:47 PM
dillsrotary's Avatar
jersey fresh
HAHA
Old Jun 10, 2006 | 03:53 PM
Clavius's Avatar
Its all about Style...
Um.. you try closing your legs!?!
Old Jun 10, 2006 | 04:06 PM
DOMINION's Avatar
Old Jun 10, 2006 | 07:11 PM
presequel's Avatar
ay bay bay
maybe you have B.O. and its not the car.....
like in seinfeld....you're infecting everything around you O_O
Old Jun 10, 2006 | 07:43 PM
stickman's Avatar
Hmmm, the common denominator seems to be you.
Old Jun 10, 2006 | 08:02 PM
Student Driver
You'd smell fish if you have this in your 8...
Old Jun 10, 2006 | 08:44 PM
BunnyGirl's Avatar
Try something called Frigi-Fresh (sp?). It's supposed to take smells out of AC.
Old Jun 10, 2006 | 09:31 PM
tiggerlee's Avatar
^Yeah I think Massengill makes something too, but not for A/C's
Old Jun 10, 2006 | 11:37 PM
NgoRX8's Avatar
this is a good reason for me not using the A/C
Old Jun 10, 2006 | 11:40 PM
Freddie's Avatar
Could it have anything to do with your sig ?
Old Jun 11, 2006 | 06:17 PM
KeithL's Avatar
mmmmm, Pale Ale!
what she said. I've never tried it myself, but the Car Talk guys recommend it.
Check your condensate drain & make sure it's not plugged up. Also, try turning off the a/c and just running the fan for a few minutes before you shut down to try to dry out the evaporator coil.
There are worse things - in my old car, unless I did that, the a/c would smell like a urinal that hadn't been flushed in several weeks. gah.
Old Jun 11, 2006 | 06:55 PM
DOMINION's Avatar
Naa my face would when I got finished
Oh yeah how do you know?
Old Jun 11, 2006 | 07:19 PM
Easy_E1's Avatar
Plug it in Plug it in,,,,,,,,,,,,,,,
Old Jun 11, 2006 | 07:22 PM
tiggerlee's Avatar
Because yes I too have had those "not so fresh" moments.
Old Jun 11, 2006 | 07:30 PM
3MTA3's Avatar
Where's My Car?
Smells like fish, it's a dish.
Smells like cologne, leave it alone!
Old Jun 11, 2006 | 07:42 PM
That dead fish I put under your hood at Rick and Ronnies seems to be doing the trick.
You have to look real hard to find it.
HA HA HA HA HA
Old Jun 11, 2006 | 07:43 PM
DOMINION's Avatar
Oh thats bad lol
Old Jun 11, 2006 | 08:18 PM
Winfree's Avatar
Now that you have bathed, changed your shoes and socks and seen your local doctor -
Try running your heater for about 30 minutes, then your AC, then repeat and see if the heat will dry out some of the mold, bacteria or whatever.
There is probably a lot of tree pollen or other organic fluff in your area and the whole East coast is much wetter than normal.
Change the filters and take a close look at your intake, Swab out the intake with some rubbing alcohol (no, you can't drink this kind) and make sure the port is dry before you run your AC. Then, with your AC off, take a hair dryer, and blow into into your out ports, and intake port.
If this doesn't clear it
Look under your battery and all of your plastic containers: sometimes leaves and stuff gets dropped down there and needs to be vaccumed out- if your area has insects and rodents, or if the inside of the hood is damp, after a run (so the area under your hood is still warm), place a couple of moth ***** on the metal brackets on either side, over the screws - close the hood and leave overnight, these will vaporize and chase a lot of pests out and also act as an antifungal. If you are real lucky you can find the cedar scented ones that are prepackaged in little 'tea-bags'. Open the hood in the morning and removed the residues (if any) and wipe the area out - don't run with chuncks of mothballs in the engine compartment - they can burn. Don't put them on the plastic covers, They may stain.
Check your fire wall material - if it gets wet it has a lot of organic material that can cause problems - a hair dryer can help, but you may even have to change it out (a real pain as its about $100 a panel and you will have to pull the AC. Your dealer can charge up to $500 for the proceedure. This is covered in part by comprehensive insurance.
You are not alone in your misery there is another thread on this - he has a different bug but same problem - his smells like sour milk.
Rots o Ruck
Old Jun 11, 2006 | 09:30 PM
DOMINION's Avatar
Thanks for the help Winfree. I tryed to bur some in-scents but it only last for a day or 2.
Old Jun 11, 2006 | 09:46 PM
AirlockRX's Avatar
Upsilon Sigma Mu Chi
