drag a racoon underneath car check engine light on after?
Old Jun 9, 2006 | 01:42 AM
mauricio's Avatar
Question drag a racoon underneath car check engine light on after?
what happened did this thing break the cable that connects to the os2 sensor to the catalyc conventer or what could it be?
Old Jun 9, 2006 | 02:42 AM
that is a very good guess..
Old Jun 9, 2006 | 06:27 PM
woodysjh's Avatar
I already searched!!!!!!!
unhook coon from cat first, then fix the wire.
Damn Coons!!
Old Jun 9, 2006 | 10:04 PM
zoom44's Avatar
whats the code?
Old Jun 9, 2006 | 10:32 PM
Sure is better than running over a Minnesota skunk!
Old Jun 10, 2006 | 05:57 AM
Go48's Avatar
Check the oil-level sensor connector on the drivers side of the oil pan while you're at it.
Old Jun 10, 2006 | 01:29 PM
toxin440's Avatar
I hit a raccood and did 2K in damage by cracking my front bumper, ripping off my undertray, and damaging my A/C condenser.... just recenly I took off my OEM cat and put in a RP Supercat, upon inspection of the old cat I found baked on blood from wher the coon hit it (actually him it 5 months ago) but heh it was funny to see blood still there
I could totally see the little bugger ripping the o2 sensor cable if he hit just right
Old Jun 10, 2006 | 03:21 PM
Originally Posted by zoom44
whats the code?
Exactly, it could be completely unrelated to what happened. To diagnose any CEL you need to know the code ...
Old Jun 14, 2006 | 01:15 AM
mauricio's Avatar
had the catalyc converter replaced under warranty
good news the mechanic checked the code and replaced the catalyc converter covered under the warranty
Old Jun 14, 2006 | 02:09 AM
NgoRX8's Avatar
so what happened to the cat? did the raccoon knock the o2 sensor or did the it damage the cat somehow?
Old Jun 17, 2006 | 01:13 AM
juikster's Avatar
Im 8 drifting on a budget
jack it up and take a good look. ....do damage inspection, heh,I'll loan you the jack and crawler....
vapor2
Nov 3, 2020 03:38 PM
delicious_dallan
Jan 17, 2020 09:17 AM
Skyl3r
Dec 2, 2019 04:51 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
