Agency Power pulley and CEL
Old Jun 8, 2006 | 06:21 AM
Mazda-Rati's Avatar
the WANKEL made me do it
I installed the pulley 2 days ago and now have codes P0300 (random misfire) and a U0073 (CAN communication error) I tried to reset the KAM and VNRAM and these codes come back.
I don't want to remove the pulley because there are no signs of performance loss as this CEL only comes on at WOT after 6K.
As for a quick review of the pulley....VERY worth the money. The power in the mid rpms is def. more noticable. By far the best bang for the buck (minus the current CEL ) Also, this was mentioned on the boards before and believe it or not the exhaust sounds a bit different (a tad louder) with this pulley. I can't explain why though.
Any ideas with the CEL?? Thanks
Old Jun 8, 2006 | 07:37 AM
whenson417's Avatar
Did you somehow remove or move that toothed crank positioning ring thingy that was right behind the pulley? That is the only thing I can think of that may cause your problems. Someone posted about a similar problem after installing the agency pulley about a week or so ago so if you do a search you may find the solution. I would provide the link but I suck at that kind of stuff.
Old Jun 8, 2006 | 11:35 AM
staticlag's Avatar
The Professor
https://www.rx8club.com/series-i-tech-garage-22/help-installed-pulley-now-getting-cel-91003/
Old Jun 8, 2006 | 08:41 PM
Mazda-Rati's Avatar
thanks for the link staticlag. i've done that (20 brake presses in 8 seconds KAM reset) and for some reason the CEL doesn't turn off when I start the car. I see the oil needle sweep half way and back and then start the car right?? I went ahead and put the stock pulley back on and manually cleared the codes with my scan tool, but they came back just as before.
Old Jun 8, 2006 | 10:16 PM
Mazda-Rati's Avatar
I ended up just unplugging the battery and putting the AP pulley back on to see if that would do the trick. sure enough the CEL hasn't come back after my test drive Is it normal my car doesn't respond to the KAM reset??
Old Jun 9, 2006 | 02:48 AM
yes i have found also that to clear the kam you have to remove the batt cable... i have done this a couple of times to reset the ltft..
Old May 30, 2007 | 05:35 PM
grinn253's Avatar
Exclamation
Just installed AP pulley and performed the > 20 pedal stomp in 8 seconds. The oil pressure gauge did its sweep, but still have the flashing CEL on WOT > 6000 RPMs. I too will try the unplugging of the battery and depress brake pedal to reset the eccentric shaft profile.
Laters!
Edgardo
Old May 30, 2007 | 08:49 PM
you have to clear the ECU memory, those in-car tricks won't do the complete trick
Old May 31, 2007 | 09:40 PM
rxAMZ's Avatar
When I put my agency pulley on I got the same CEL as well,
all I did was used the brake tapping to reset. stayed on for a few days then
suddenly went away. I figured as it's learning ecu it'd juz get used to it
could be wrong,
Old Feb 15, 2009 | 02:52 AM
DOMINION's Avatar
I don't buy Kool-Aid
Good read! just installed my AP Pulley tonight and that dam cell came on. I pulled over pulled out my Scangauge2 hit delete but it keeps coming back gerrr. Guess I'm going to unplugging my battery too. How long should I let it sit for?
Old Feb 15, 2009 | 08:04 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Don't have to do it this long, but give it 15 minutes.
Old Feb 15, 2009 | 09:37 PM
DOMINION's Avatar
^Thanks man!
Old Feb 16, 2009 | 04:40 AM
AJ's Shinka's Avatar
Enthusiast
What have you guys felt with the new pulley? Any difference in power?
Old Feb 16, 2009 | 09:49 AM
Jon316G's Avatar
Grasshopper
I honestly didn't feel a difference.
Old Feb 16, 2009 | 02:26 PM
Enthusiast
^^^Interesting.
Old Feb 16, 2009 | 03:15 PM
Mazurfer's Avatar
I don't have the Agency, but rather the Unorthodox set and to be honest, probably only felt like there was a change for the better in throttle response. It was noticeable though.
Old Feb 17, 2009 | 05:01 AM
DOMINION's Avatar
Yup same here. Car moves after 5k rpms WOT! I love it. But hate that dam cell gerrr
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RXFEVER
Sep 11, 2016 02:51 PM
