wind noise
Old Jun 5, 2006 | 05:54 PM
limepro's Avatar
wind noise
at around 65-70 i start hearing wind as if its coming through the windshield me and someone else while driving tried to find the problem but found nothing has anyone else had this and how did it get fixed? other than that i love this car im so happy everytime i have to drive anywhere
Old Jun 5, 2006 | 06:10 PM
8 lover in Japan's Avatar
yeah...its happened in a couple of my cars. but i dont think it would be from the windshield, more likely from the top of the door. the rubber might not be sealing properly...and on really windy days you can hear it more...if you cant get it fixed yourself, try your dealer. but so it seems, most guys dealers arent worth much. good luck.
Old Jun 5, 2006 | 06:17 PM
limepro's Avatar
ty ty ill try the dealer
Old Jun 5, 2006 | 06:18 PM
mysql101's Avatar
my driver side door has a wind sound at high speeds. I don't think the dealer will be able to fix it for you as it's just the sound of wind blowing across the panels.
Old Jun 5, 2006 | 06:21 PM
limepro's Avatar
mine sounds like its coming from the top middle of the windshield maybe the seal is loose or the trim came loose but im not an expert ><
Old Jun 5, 2006 | 06:23 PM
mysql101's Avatar
have a sunroof?
Old Jun 6, 2006 | 10:56 AM
limepro's Avatar
Originally Posted by mysql101
have a sunroof?
yes yes i do
Old Jul 10, 2006 | 07:40 PM
Rinkadink's Avatar
I don't have a sunroof and I also get the windnoise above around 75-85mph. It sounds like its coming from the top part of either the door or the window sill. But yeah, exact same issue.
Old Jul 10, 2006 | 07:54 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
maybe your door rubber tubing on the door isn't on properly or is falling off due to defective part....make sure everything is fitted in! good luck finding the problem
P.S.- your car would look sick with JDM Clear corners, maybe look into investing in a pair!
RedSheDevil's Avatar
.:. causing mischief
have you ever tried opening the sunroof a bit then closing it when you are hearing the wind noise? my sunroof has just started rattling when in the open position; so I wonder if they don't "seat" properly and mebbe that is where your noise is coming from.
Old Jul 10, 2006 | 10:25 PM
limepro's Avatar
ya ive tried that it kind of sounds like a radio when its only getting static and its in front of me it happens like as soon as i hit 70
Old Jul 11, 2006 | 03:58 AM
DOMINION's Avatar
I don't buy Kool-Aid
You should try closeing your vents in the car?
When I drive at high speeds I can hear the air from the vents coming in.
Old Jul 11, 2006 | 08:55 AM
Hightshoe's Avatar
'05 Titanium 6sp
If theres a cross wind at just the right angle, i can hear wind noise coming from my drivers side mirror. anyone else get this? Its not that big of a deal since it rarely happens.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
