Why not coat the turbo housing?
Old Jun 5, 2006 | 03:29 AM
Xantium's Avatar
Unregistered User
I've seen little reflective jackets that go on turbo's... but why not cermaic coat them?
http://sportcompactcarweb.com/featur...road_race_car/
But here’s the really clever bit; Ed had Turbo X thermal barrier coatings applied to the exhaust manifolds and turbo housings, while the intake piping and plenum get a full treatment of Cermakrome—another brand of thermal barrier coating.
The result? A 100-degree F drop under the hood. Not only does the cooler air mean more power, it means less boost required from the turbos and an engine that is less stressed. The turbos also spool up faster by retaining interior heat better and scavenging waste gas more effectively, another important weapon in the war against lag. Greater efficiency with greater reliability; it’s a win-win situation.
Seems like you'd have to be to go without coating on a turbo.. why is it that no one does this? Side effects?
Old Jun 5, 2006 | 07:24 AM
rkostolni's Avatar
I had myne coated when it was rebuilt, along with downpipe and manifold. I think its a good idea for anyone with a turbo'd rotary considering how hot they run to begin with.
Old Jun 5, 2006 | 07:56 AM
Rootski's Avatar
DGAF
I must not be getting something here. How can keeping heat in the turbo drop the air temp?
Old Jun 5, 2006 | 08:38 AM
Guisslapp's Avatar
Heat goes out the exhaust instead of into the engine bay, I guess. And ceramic coating the cold side may keep the heat out.
Old Jun 5, 2006 | 10:58 AM
Trekk's Avatar
Goat rider
From the turbo's I've had in the past. Heat wasn't really a big issue unless I was racing it or under boost alot.
Dont get my wrong, anything will help, but most people dont do back to back races. Most times Ive spent at the track, I had to wait 20 or more Min. between runs. It's cooled off pretty well in those times.
I've ALWAYS used Thermal tape on my down pipes to make sure that heat stays out.
Thats an easy do-it-your-self-in-a-few-min Mod.
Old Jun 5, 2006 | 11:26 AM
rotarygod's Avatar
The more heat you keep in the exhaust system, the less gets radiated anywhere else. This means there is less underhood heat that is coming off of the turbo. Less underhood heat means that the intake and everything else under the hood also stays cooler since it all absorbs heat. Any heat in the intake manifold gets picked up by the air entering the engine.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
jamespond24
Dec 1, 2015 11:11 PM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
GK1707
Sep 27, 2015 07:33 PM
