Whining noise debate (please read, responses welcome)
Old Jun 2, 2006 | 10:45 PM
edblor's Avatar
RX-8 Taker Arounder
Arrow Whining noise debate (please read, responses welcome)
Hi peeps,
My '05 AT RX-8 produces a distinct "whining noise" at each shift point. Either in sport mode or full auto. I can also produce this noise by getting up to speed, popping into neutral, and revving up gingerly. So in other words, it seems to do this under load, and not-necessarily under load
This "whining noise" has been getting louder as I have owned the car, and now produces a slight rattling in the shifter.
I took it to the dealer that sold it to me, and they first said they could not reproduce the sound (insert laughter here). It's odd that it happens to me AT EVERY SHIFT CHANGE!
I took it to another dealer that I have always been more fond of (bought my Mazda3 from them back in '04), and they oddly enough say that they cannot hear the "whining sound", but are going to replace the rear passenger wheel bearing, and the right engine mount. They say they hear a humming from the rear, and that the engine mount is fluid filled, and leaking.
Anyway, I'm concerned the "whining sound" is not engine mount related or right wheel bearing related either.
I just can't see how the whining is produced by the faulty engine mount.
Regardless, I'll let them fix these two problems (under warranty ) and see if it solves the problem.
Any comments?
Edblor
P.S. Thanks for hearing me out, perhaps someone else has had this issue. I did do a search, and came up with various problems and solutions. I'm not confident mine is similar though.
Old Jun 11, 2006 | 02:33 PM
edblor's Avatar
RX-8 Taker Arounder
My dealer ordered the new front right engine mount, and rear right wheel bearing, so I took it in last Friday.
They had it the whole day (8AM to 5PM) and only replaced the right engine mount (wrong part ordered for the wheel bearing).
Anyways, the whining is still present, and I noticed on the workorder that they hear the whining sound, but claim it is "normal".
Wow, just fvcking wow!!!!!!
What has anyone else done to actually have them fix this? From the sounds of it, they do not intend to look further into it. I have read other posts about differentials being replaced, trannies being replaced, and even new engines!
Anyone have anything to add????
Thanks,
Ed
Old Jun 11, 2006 | 06:54 PM
zoom44's Avatar
why dont you ask them why it is normal. what is it that makes the noise?
Old Jun 11, 2006 | 07:29 PM
Easy_E1's Avatar
I have had 2 '05 AT's and have not heard the sound you are describing.
I shift in sport mode all the time,, I shift about 4000-5000 rpm in normal driving and have heard nothing.
Nor have I heard this noise at full rpm.
Try to be a bit more descriptive of the sound you are hearing. And what is happening at the moment of this sounds occurance.
Old Jun 11, 2006 | 09:11 PM
edblor's Avatar
RX-8 Taker Arounder
When in gear, the "whining" happens at shift points, for about 1 to 1.5 seconds AFTER the shift change. When not in gear (neutral), I can reproduce the "whining" noise by revving up to various RPMs (depending on how fast I am going, in other words, getting up to speed (60KM/h) and popping it into neutral).
This "whining" noise kinda sounds like a belt rubbing against metal, or perhaps metal on metal. Not super loud, but most definitely audible. Sounds like a screeeching sounds.
Now that the nice weather is here, it is more apparant with the windows down.
There are no noticeable rumblings or other noises, nor is there ant loss of power. Just his annoying whining noise.
Sorry I cannot be more specific about what it sounds like!
Old Jun 13, 2006 | 04:25 PM
zoom44's Avatar
sounds like normal intake operation to me
Old Jun 13, 2006 | 04:39 PM
edblor's Avatar
RX-8 Taker Arounder
I guess I could describe the sound as closer to a whistling sound. It is MOST DEFINITELY not the intake.
It's not air rushing into the intake. It sounds like metal on metal, or a belt on metal. It happens right after a shift (either mode), and I can replicate it while in neutral, but only when the car is moving.
When in gear, it happens after the shift, and is about a second in duration. When in neutral, but moving, I can replicate and sustain the sound.
Old Jun 13, 2006 | 05:38 PM
zoom44's Avatar
i dont mean air i mean the operation of the mechanical bits of the intake manifold. SSV APV etc
Old Jun 13, 2006 | 05:45 PM
edblor's Avatar
RX-8 Taker Arounder
Then why does'nt every RX-8 sound like this? AT or MT?
And to be honest, it is an annoying sound. If I knew my car was going to make an annoying sound at every shift, I would not have bought it!
Would you have?
Old Jun 13, 2006 | 06:12 PM
zoom44's Avatar
havent heard your noise so its hard to say- but every rx-8 makes noises whenthe various bits of the S-DAIS system do their job. it depends, of course, if i would find the noise annoying,yes? maybe i wouldnt. did you ask the dealer why the sound was normal?
Old Jun 13, 2006 | 06:16 PM
edblor's Avatar
RX-8 Taker Arounder
I should be bringing it in to get the right rear wheel bearing finally replaced.....I'll ask them then why the noise is normal!
Old Jun 13, 2006 | 06:18 PM
RedSheDevil's Avatar
.:. causing mischief
my car makes a mysterious rattling noise in neutral. it disappears when you depress the clutch. funny thing, i thought i just had to tighten something, but nope! at the last meet three of us have the same sound. i think they all make some sort of weird noise, but i dont have an AT so i can't answer your question.
take your service writer on a test drive when you bring the car in ... drive him around until he hears the noise, or is so sick of driving around that he will replace just about anything to make you go away
Old Jun 13, 2006 | 06:20 PM
zoom44's Avatar
RSD- if the MT noise goes away when you push the clutch pedal in thats normal gear rollover noise.
https://www.rx8club.com/showthread.p...se#post1198623
https://www.rx8club.com/showthread.p...rollover+noise
etc...
Old Jun 13, 2006 | 06:22 PM
thanks!!!!
but damn, i thought i could fix it super easy with a wrench or some wd-40!!!
Old Jun 13, 2006 | 06:24 PM
zoom44's Avatar
edited above - added some links for furthur study
Old Jun 13, 2006 | 07:09 PM
Tanx Zoom!
Old Jun 13, 2006 | 07:29 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I hear a distinct whining sound from within the above post. Honestly, it is highly annoying. If I knew it was going to be this annoying, I would not have read this thread.
Old Jun 13, 2006 | 07:32 PM
^ LOL you want your two minutes back?
Old Jun 13, 2006 | 07:40 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Please!!!! You got???
Old Jun 13, 2006 | 08:56 PM
zoom44's Avatar
does this read like what you are experiencing?
https://www.rx8club.com/showthread.p...862#post145862
Old Jun 14, 2006 | 09:06 AM
edblor's Avatar
RX-8 Taker Arounder
TYVM for the info zoom44 (finally, a response relevant to my thread).
I will check out my odd sound really closely today, but I think it only occurs at 4k or higher (that's about the RPM that I can reproduce it at).
Perhaps it is jut more ports opening, and what I am hearing is additional rushing air needed to feed them.
Thanks again
Edblor
Old Jun 14, 2006 | 09:28 AM
yanno for a n00b you're awfully cocky. your thread title states RESPONSES WELCOME. wow, you might actually learn something about your car while busy complaining about it.
maybe you should just sell it after all ...
Old Jun 14, 2006 | 10:45 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
^^^Yes I find your response, Red, extremely relevant to the debate. I, too, thought my responce was pertinant and relevant to the whole debate. We both were simply discussing perceived noise that was bothering us, both for differing reasons. I am not sure why the original poster finds our contributions to be superfluous. Perhaps it is a result of his condition.
Hey Ed! Want some cheese with that whine???
Old Jun 14, 2006 | 11:25 AM
edblor's Avatar
RX-8 Taker Arounder
No thanks! But unless you have something to add that is not sarcastic, or negative to my original post, please keep your comments elsewhere.
I think you will note that zoom44's comments were both respectful, and helpful.
Cheers,
Ed
Old Jun 14, 2006 | 11:47 AM
Hightshoe's Avatar
'05 Titanium 6sp
To find out whether this is what the noise is do the following. when you hear the whinning, step on the gas, it should go away rather quickly becaue the intake will open up all the way. Every 8, as far as I know, has the whinning noise at certain times.
