newbie ??: rx8 13b vs rx7 & Turbo II
Old May 29, 2006 | 08:26 PM
VRRX8's Avatar
Talking newbie ??: rx8 13b vs rx7 & Turbo II
can you fit a twin turbo from an fd, or a single turbo from a fc, since they are both 13b's???
Old May 29, 2006 | 08:38 PM
Skythe's Avatar
Lascivious Post Whore
the flames shall soon be upon you
supergoat's Avatar
I don't "smell good".
Yea. Hell a 20b will fit.
But there's more to it than just slapping it in, the next step is getting it to run right.
Old May 29, 2006 | 08:39 PM
VRRX8's Avatar
what about just the twin turbo kit or the turbo kit forom the TT, can they bolt on to our renesis??
Old May 29, 2006 | 08:42 PM
BlueEyes's Avatar
No, but they duct tape on.
Old May 30, 2006 | 06:41 AM
Mugatu's Avatar
Even My Dog Searches
i heard you can put two turbos and a supercharger on, and you'll be all set. don't forget the nitrous too. you'll be unstoppable.
Old May 30, 2006 | 07:02 AM
You can put a 1NZ-FE in it. Its going to rock your world !
Old May 30, 2006 | 07:51 AM
Beodude123's Avatar
The exhaust ports are in a different spot, so the exhaust manifold wouldn't line up.
Old May 30, 2006 | 01:05 PM
Blue87Sport's Avatar
Rotary only since 1980
The correct answer is that with enough time and money anything is possible, including putting a FD or FC engine in the 8. But neither will just drop in, you would have to do a *lot* of custom fabrication and EMS work.
Old May 30, 2006 | 01:08 PM
StewC625's Avatar
Insanely Yellow
How about a carbureted 12A from a 1985 RX-7 1st generation?
Only thing I can't figure out is where to put the choke ****.
Attached Thumbnails newbie ??: rx8 13b vs rx7 & Turbo II-rx-7-03.jpg
Old May 30, 2006 | 02:26 PM
rotarygod's Avatar
If you are asking if you can just use the turbos themselves with a Renesis the answer is yes. However it isn't a direct bolt-on affair. The Renesis has 3 exhaust ports while the 13B only has 2. This means you will have to do some custom fabricating of a new exhaust manifold to make them work. This doesn't really make it worth all the effort. While it may be posible to make it work, there'd be better ways to spend your time and money.
F51
Aug 2, 2021 04:07 AM
Mxttz0r
Jul 5, 2019 03:19 AM
KingBonacci
NE RX-8 Forum
Jul 22, 2015 11:25 PM
RX7.9
Jul 20, 2015 12:01 PM
shambo
Jul 18, 2015 02:07 PM
