Oil Additive for extra lubricant?
Old May 29, 2006 | 10:43 AM
Benjam's Avatar
Guys,
Is it safe to use any of the Oil additives on the market to give that extra lubricant and protection for the Rotary engine?
Old May 29, 2006 | 10:56 AM
StealthTL's Avatar
Metatron
Arrow I wouldn't....
I see no reason to add any additives to your oil.
If you pick the wrong one, maybe it contains Zinc Phosphate or similar, (proven to reduce wear) but it can screw up your catalyst when it burns in the rotor housing.
Leave the oil compounders to do their job, you are not smarter than them
S
Old May 29, 2006 | 10:57 AM
rotarygod's Avatar
Is it safe to? Sure. I need to ask why? Is the oil you are using inadequate? My logic is that if your oil needs additional additives, you should just be using a better oil. I don't see why you can't though. I'm just not a fan of them.
Old May 29, 2006 | 11:54 AM
alnielsen's Avatar
Originally Posted by Benjam
Guys,
There are so few moving parts in a rotary engine that there shouldn't be any gain. The only type of additive that may help is the use of a detergent additive used before you change the oil.
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
Slack
Sep 5, 2015 06:42 PM
chris424
Sep 2, 2015 10:18 AM
