special tool for removing front rotors?
Old May 25, 2006 | 12:27 PM
Ophitoxaemia's Avatar
dizzy snake pilot
didnt see this answered in the threads i searched.
are the front phillips head screws that hold the front rotors locktited? will i be able to remove them with a large screwdriver? will i have to heat them to soften the locktite? i think i read about a special tool to remove these, is it needed?
if they arent glued in there i will be ok. will be doing this in a hurry saturday morning so want to have any special equipment ready (other than my usual torch and large hammer )
thanks,
james
Old May 25, 2006 | 12:41 PM
rotarygod's Avatar
I have a little impact tool that is designd for such things. It is a little handheld thing that can ue either a phillips head or a flat tip bit. It is spring loaded. You hold it up to the screw and hit the end with a hammer. It might take a few hits but it'll break them loose. Then you just use a regular screwdriver. Don't try to just use a screwdriver only. If they are on there tight enough, you'll just strip them out. Then you'll be in trouble. Go up to the hardware store and pick up a little impact driver for a few bucks. You'll be glad you did.
Old May 25, 2006 | 03:25 PM
dizzy snake pilot
thats exactly what i was thinking of. i will definitely pick one up. thanks!
james
Old May 25, 2006 | 04:27 PM
BlueRenesis82's Avatar
Registered Tracker
yeah, after you use it once, its not necessary unless you really drive 'em back in
Old May 25, 2006 | 05:32 PM
StealthTL's Avatar
Metatron
Wink Aunty Seez......
One of the first things I did when I bought, was put a bit of Never-Seize on those screws (while they where nice, shiny and new!) I also do my wheel studs, the salt can seize an alloy wheel to a steel rotor very quickly.
Changed my rotors to "drilled" type this spring - no impacts required....(where is that "smug" emoticon?... )
S
Panthersn
Jul 13, 2021 06:30 AM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
AussieGray
Jul 16, 2015 03:58 AM
